swapping blowin 305tbi for a gud used 305 tbi
Old Jul 26, 2008 | 10:17 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
just need advice, and or help. I own a 1991 camaro rs 305 tbi automatic ran great but car was from up north and had way to much rust and holes. I bought a 1991 camaro rs 305 tbi automatic which had a blowen engine and only first and second gear, great body. I just got done with the swap and the engine that ran fine is blowing smoke and lacking power. I tried to get it on the road and it seems like it is flooding out not 100% sure. Please HELP
Last edited by weswisehart; Jul 27, 2008 at 11:08 AM. Reason: left out a few words
Old Jul 29, 2008 | 05:51 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: swapping blowin 305tbi for a gud used 305 tbi
Try the other computer. A couple other things it could be are vacuum lines and cracked dizzy cap(left on during install). If the smoke is black then you are flooding the car. I would check or replace the cap, and look for anything disconnected first.
Old Jul 29, 2008 | 04:35 PM
Car: 91 RS T-top
thanks I will swap the computer. That is behind the dash on the Passenger side right? What is a dizzy cap and where is it located?
Old Jul 29, 2008 | 09:22 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
Dizzy Cap=Distributor cap...all the spark plug wires run into it.
Old Jul 30, 2008 | 09:46 PM
Car: 91 RS T-top
thanks thats what I thought he meant. I've just never heard it called that.
Old Aug 2, 2008 | 02:03 AM
Car: 91 RS T-top
thanks car runs good i cut off most of the vaccum hoses and plugged them. Now the transmission doesnt seem so smooth. I post that in another area thanks again.
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
