Can't check base timing . . what the!?!?
Car: 91 RS
Engine: 350 TBI
Normally we just unplug the brown/black wire near the passenger side of the firewall and check it, but now every time I do it the car just shuts off.
Re: Can't check base timing . . what the!?!?
When I check the timing, I always unplug the wire before starting the car. Have you tried it that way, or did you unplug the wire with the engine running?
Car: 91 RS
Engine: 350 TBI
Car: check
Engine: check
Transmission: check
Warm up the engine then unplug the bypass. Now start it and work the gas pedal to keep it running. As the gas-pedal reaches fully released the IAC will start to open to raise the idle speed.
May need to tap the pedal to keep it going, but sooner or later the IAC should open enough to hold an idle speed. It's a pain, but once the IAC opens enough it will stay running.
Warming up the engine before timing the engine is important for several reasons.
RBob.
RBob.
Car: 91 RS
Engine: 350 TBI
The engine was pretty freakin' hot when I tried it. I also tried the gas pedal thing and it didn't matter. Literally it dies in second, if that.
