Coolant Temperature sensor Issue!
Old Jul 27, 2008 | 10:30 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
OK, So I have had multiple issues with the coolant temp plug on the passenger side head. I was having fan issues replaced the sensor and the pig tail because it was the orginal and the pig tail had burned. Run it a few times issues again the pig tail burned. I then put headers on the car. I put another new pig tail on it. Now I was out driving it around and the temp sensor guage went dead. I assume again the pig tail is burned. Is there any fix for this?
Old Jul 27, 2008 | 11:28 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Coolant Temperature sensor Issue!
the sensor on the pass head between cyls 6 and 8 doesnt affect gauge. that sensor is actually the fan switch. there is also a sensor on the intake and one on the driver side head between cyls 1 and 3. i forget which one does the gauge. i think one is the gauge and one feeds the ecu but i forgot which is which
Old Jul 27, 2008 | 11:35 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
If i recall correctly the one on the intake feeds the ECU, and the one between 1 and 3 feeds the gauge. When the one on the intake went bad in my car, it caused a surging idle.
Old Aug 8, 2008 | 09:20 PM
THE87IROCZ's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7 performance crate motor/TPI
Axle/Gears: Stock posi
The one on the drivers side runs the gauge, the one on the intake is for the ECM and the one on the passenger side runs the high speed fans, low speed is controlled by ECM I believe. You could always run a wire and toggle switch to under your dash. Just make sure u run a wire from the switch to a ground in order for it to work.
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
