Trans am hard to start when warm
Old Jul 31, 2008 | 11:00 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
I have a 1985 trans am TPI that will start up when cold but when warm it is harder to start by a few more sec. what could be the problem thanks.
Old Aug 1, 2008 | 12:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Trans am hard to start when warm
what do you mean harder to start?
cranks over very slowly, barely catches?
cranks over fast, but won't catch?
etc?
Old Aug 1, 2008 | 09:39 AM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
It cranks over more times before it starts.
Old Aug 1, 2008 | 09:45 AM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
Sometimes i can smell gas so i dont know if it is giving it to much or what but onley does it after the first start when it warms up then when you go to start it maby 10 mins later it takes more cranks to start.
Old Aug 1, 2008 | 10:05 AM
'87 Bird's Avatar
Car: 1987 Formula
Transmission: 700R4, shift kit
Axle/Gears: 3.23 Posi
91 Ragtop told me he had the same problem and the fuel injectors were the culprit. Does it have a semi-rough idle as well? Mine has a rough idle and does the same thing yours does. I plan to get new injectors as soon as possible.
Old Aug 1, 2008 | 10:42 AM
bigzeke's Avatar
check map sensor and look for any small vacuum leaks --------------bigzeke355bird92
Old Aug 1, 2008 | 10:48 AM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
yeah my car idles high and it is all the way down that i can get it but somtimes if i give it a quick tap on the gas pedal it lowers the idle.
Old Aug 1, 2008 | 11:13 AM
bigzeke's Avatar
a couple of things you need to look at here ,one reason why you may be smelling gas is if map sensor is not sending accurate vacuum signal to ecm than the injectors may be dropping too much fuel ,also need to look at fuel pressure regulator they loose calibration from all that heat ,with the car started take a wrench and tap on regulator see if you notice a change in idle characteristics can also get this same symptoms from faulty o2 sensor not feeding correct oxygen mixture signals this will give you same effect ------------bigzeke92bird355 150 shot hitman
Old Aug 1, 2008 | 11:31 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Next time it does it check for spark. A bad module will tend to fail on a hot restart. Other ignition components may also fail under heat soak conditions.
Bad sensors shouldn't cause a hard start. The ECM should be in non-feedback mode during starting.
The gas you're smelling is likely the normal amount that is fed to the motor, it's just not burning because the engine isn't starting.
There could, of course, be other causes but best to check the basics next time it occurs...fuel, air, spark.
Old Aug 1, 2008 | 12:01 PM
bigzeke's Avatar
i beg to differ a bad map sensor will cause a rich condition ,usually a bad module will need to cool if its faulty ,been teaching automechanics for a long time ,look at your map sensor and check for vacuum leaks if map sensor isnt working within its parameters then its fooling the ecm into dumping more fuel this fuel is unburned therefore you smell it --------bigzeke355bird92
Old Aug 1, 2008 | 12:07 PM
bigzeke's Avatar
sid a bad map sensor ,o2 sensor will cause you a rich condition this could explain why it takes the car longer revolutions to start because the cylinders have excess fule in them ,also some coolant temp sensors will havew the same effect if this sensor is bad then the ecm cannot recognize the correct temp of the coolant therfore it thinks the coolant is cold and it sends more fuel to the injectors ,you know how on a cold mornig car idles up until its warm this is because of the coolant sensor so dont believe sensors cannot cause a no start or hard start condition because they can ---------bigzeke355bird92
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
