oil leaking on intake from center 2 bolts
like the title says im getting puddles of oil on th eintake from the center intake bolts,under the carb,i have trick flow heads and a performer intake,i think the holes go thru the head,not a blind hole.is oil wicking its way out the bolts?do i need selaer and if so what kind if engine/ol freindly
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil leaking on intake from center 2 bolts
Yes, you need sealer on the intake bolts. Liquid teflon works well.
Transmission: 4L80E/4L80E
I've never had any problems with the liquid Teflon. It actually has a higher temp rating than the typical black RTV.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
