Draining fuel line?
Old Aug 6, 2008 | 08:36 PM
Chuck's Avatar
Draining fuel line?
'89 RS apparently needs a fuel filter.
To drain line, manual says to remove the fuel pump fuse and
wait until engine quits.
About how long would you expect engine to run
before quitting?
Thanks!
Old Aug 6, 2008 | 09:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Draining fuel line?
On fuel injection, maybe a second. On a carb, maybe 10 or 15 seconds, depending on bowl volume.
Old Aug 6, 2008 | 09:47 PM
Chuck's Avatar
I must not have pulled the correct fuse.
I pulled 20 amp f/p,fan,CH.
I see there are 2 other 10 amp f/p inj1, f/p inj2
Or???
Chuck
Old Aug 6, 2008 | 10:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Knowing something about what kind of car and engine you're dealing with would help.
Old Aug 6, 2008 | 10:13 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
on carb don't matter how many fuses u pull the pump its mechanic but apparently u got fuel injection if you got f/p inj1 and f/p inj2
Old Aug 6, 2008 | 10:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe it is, maybe it isn't. An 89 never came with a carb, with or without a mechanical fuel pump. We need him to tell us.
Old Aug 7, 2008 | 12:58 PM
Chuck's Avatar
Certainly. Sorry about that.
'89 RS, 350 TBI.
I loosened the connections on the
fuel filter and it seems to be
syphoning gas from the tank.
Any ideas?
Old Aug 7, 2008 | 03:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Moving this to Tech/General engine since it's not carbureted.
Old Aug 7, 2008 | 03:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
350 TBI? Ok, so this was originally a 305 TBI? Then you should have a fuel pump fuse somewhere in there. F/P 1 and F/P2 seem like good starting points, yank those and see if it'll stall.
You've only got, what, 14psi in the line anway? I wouldn't lose sleep over it...
Old Aug 8, 2008 | 09:40 PM
Chuck's Avatar
Question really is this:
How can I change fuel filter without draining my
gastank in the process?
I loosened filter and it drained about a gallon before
I gave up, tightened it back up, now asking you guys...
Old Aug 12, 2008 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Change the fuel filter when the tank is nearly empty.
Old Aug 12, 2008 | 03:08 PM
eeeeeefirebird's Avatar
if you had time to let a gallon spill out you probably couldve thrown the new on. as far as i know, it cant drain your whole tank because the lines run out of the top of the tank, so gravity will help you. like sonix said, tbi should have a fairly low pressure in the line anyways, and you seem to have already relieved the pressure.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
