oil pressure sender
Old Aug 8, 2008 | 01:42 AM
denthar's Avatar
Car: !985 Chevy Camaro
Engine: 2.8L
oil pressure sender
well... i'm back again... the last step in my cluster swap, i'm replacing the oil pressure sender... i just have no clue where it is. can someone snap me a picture of its location?
i drive a 1985 camaro V6...
thank you in advance
Old Aug 8, 2008 | 03:19 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: oil pressure sender
if your talking about the sending unit, its located on the side of the oil pan, little thing that sitcks out and has wires running to it, normally has a small oil leak around it
Old Aug 8, 2008 | 03:21 AM
denthar's Avatar
Engine: 2.8L
alrighty, i'll see if i can see it in the AM thanks
Old Aug 8, 2008 | 08:33 AM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
would it be located in the same place on a 91 305 tbi third gen as well?
Old Aug 8, 2008 | 08:39 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
it would be located right above your oil filter.
Old Aug 8, 2008 | 08:58 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
if it has an oil leak around it it's because the last guy didn't use teflon (plumbers) tape around the threads.
Old Aug 8, 2008 | 09:06 AM
Doc_G's Avatar
Car: 87 Trans Am
Thanks. Added to the seemingly never ending list of things to replace on this car.
Old Aug 8, 2008 | 12:19 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
traditionally i wouldnt use plumbers tape, maybe liquid thread sealer, and most units ive seen have never been touched because people dont care to tear open their oil pan to fix a cosmetic leak that nobody sees lol
age is the leak factor in most cases
Old Aug 8, 2008 | 01:46 PM
Doc_G's Avatar
Car: 87 Trans Am
Is there an easy visual inspection to tell if my oil pressure sender is bad? Or is it one of those just replace it and be done type things?
Old Aug 9, 2008 | 03:05 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
does your oil pressure gauge give you a retarded reading? Like its not reading at all or its all over the place, if i remember correctly after i fixed mine and did an oil change i ran at a lil above the 1/2 mark on my gauge at idle and it would raise as rpm rasied like it should, its not a big deal but if you want to repalce it just do it to get it out of the way
Old Aug 9, 2008 | 03:51 AM
mercdeking's Avatar
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
A quick question, if you replace the oil sending unit, will anything leak out?
Just wondering, I know if I remove some other sensors depending on where they are out stuff will leak out. So should I prepare for getting the oil out of my car before replacing the unit?
Old Aug 9, 2008 | 02:03 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yes oil will pour out, the sending unit is a do it while you there job, replace the unit when you go to do and oil change, and judging by our cars awesome 19 years old+ gaskets, expect the have to change the oil pan gasket too, drop the pan, swap the unit, put the gasket on and fill it up
Old Aug 10, 2008 | 05:29 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
What tool do u use to remove the sender/switch??
I could not get mine out...I cannot get a wrench on it...the only thing I can think of is to go buy a closed end wrench, my best guess is that it is a 1-1/8??
Any suggestions would be appreciated.
Old Aug 12, 2008 | 01:52 PM
Car: 92 Camaro RS
Axle/Gears: Stock
I wasn't getting any love on this thread but someone answered on another...
http://www.partsamerica.com/ProductL...goryCode=3411T
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
