Fuel Filter Changing question
Old Aug 10, 2008 | 05:34 AM
Chuck's Avatar
'89 RS, TBI, Fuel Filter on rear cross member.
When I loosened the connections, gas of course
ran out. But ... it kept running out. After about
a gallon I tightened connections and am asking
you guys. Seems like it is syphoning out of gas
tank. Suggestions please?
Old Aug 11, 2008 | 06:44 AM
Scramby's Avatar
Car: 1986 IROC-Z
Transmission: Automatic
Axle/Gears: 2.73?
Re: Fuel Filter Changing question
On the TPI's, it suggests relieving the fuel pressure in the fuel system by pulling the fuel pump fuse and letting the car run until it dies from lack of fuel, and then trying to crank the system over just to make sure it's good and out of fuel. Give that a try and see if it helps ya any.
Good Luck!
Scramby
Old Aug 11, 2008 | 10:09 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
do you know which fuse it is?
Old Aug 11, 2008 | 01:48 PM
Chuck's Avatar
I thought it was the F/P,Fan,CH fuse, but apparently not.
2 fuses marked F/P - inj 1, and F/P - inj 2.
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
that shoudlnt matter, i when i did mine i sat there and waited for it to stop then realized hey....its gonna keep going, someone brought up the pressure thing so they popped my gas cap and it hissed like usual, the flow slowed down but kept going. My advice is do it fast and do it right, to speed things up once you pull the filter drain the gas into a clean bucket or something and spray the nuts with like wd40 to get the dirt off, put the new one up and have at it
a gasoline bath does the body good.......atleast ive been told so lol
Old Aug 11, 2008 | 05:53 PM
Scramby's Avatar
Car: 1986 IROC-Z
Axle/Gears: 2.73?
It's, supposedly, a fuse located behind the passenger side headlights near the battery in a black fuse box. I "believe" there is an orange wire leading to it. Once you get the filter changed, remember to put the fuse back in and prime the system. (IE: Turn the car on for a bit but don't turn it over.) I'm looking to change my fuel filter out today myself, we'll see how that goes. As far as a gasoline bath is concerned, I wouldn't suggest it. Gasoline can irritate the skin and also the eyes very badly.
Old Aug 11, 2008 | 07:08 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah the gas never stops coming out. found that out the hard way too. and yes there is a fuse located behind the passenger light on the inside of the fender. remove that one then crank the car untill it wont run. if you remove the injector fuses it wont relieve the pressure.
Old Aug 11, 2008 | 08:22 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
i had the same issue but i found that when i disconnected the fuel lines in the engine bay, not at the throttle body but where the flexible lines enter the hard lines, that the fuel stopped pouring out from the fuel filter. i know it doesnt really make sense but it worked for me after about 45 minutes of letting the fuel drain out, and no the gas tank did not run empty, there was still a lot of gas left in the tank.
Old Aug 11, 2008 | 08:45 PM
Scramby's Avatar
Car: 1986 IROC-Z
Axle/Gears: 2.73?
I just changed the fuel filter on my car.
1986 IROC-Z 305 TPI
I started by popping the hood. I then started the car. I found a fuse behind the passenger side headlight near the battery. It had an orange wire going into it. I pulled the fuse and the car immediately died. I set the fuse a side and got back in the car and tried to crank it for a while. I then jacked up the driver's side rear tire and located the fuel filter. It was located forward of the rear tire, sorta near the center of the car in kind of a recess pocket. I sprayed both sides of the fuel filter's fittings with Liquid Wrench. Then I took a lunch break. About thirty minutes later I returned to the car. I put down a crap load of old t-shirts on the ground to soak up any fuel. I used a channel lock and a 5/8" Box wrench. I started by loosening the fitting on the output side of the filter. The side where the fuel exists the filter on it's way to the engine. I did this by using the channel locks to hold the fuel filter's fitting and the box wrench on the fuel line fitting. I applied very slow pressure to the fuel line fitting until I could feel it starting to move. At this point I stopped and checked to make sure it was the fitting moving and not the fuel line twisting. Once I was sure it was the fitting, I continued loosening the bolt until I could untwist it with my finger. I did this slowly anticipating fuel squirting everywhere seeing as I wasn't 100% confident I pulled the right fuse in the first place. When I got towards the last few threads there was a spirt of fuel for a moment, and then fuel began to pour out. A bit at first then it slowed and finally came to a slow dribble. At this point I loosened the input side of the filter's fitting in the same manner. The filter is held to the bottom of the car via a bracket, or at least mine was an I just twisted it back and forth out of the bracket. Be careful not to tip the fuel filter as it still contains fuel. I installed the new filter in reverse order, taking care to ensure the filter was installed with the proper fuel flow. I must note that the fuel never fully stopped dribbling out of the fuel lines, but wasn't so much that it caused a mess that the tshirts couldn't handle. Also, while installing the new filter, I found it easier to tighten the input side fitting first. After the filter was installed and the fittings tightened down, I reinstalled the fuse and turned the car on to pressurise the system. No leaks. I then lowered the car and started it. It took a second, but it started. I checked again, no leaks. Took the car around the block and everything seems okay.
I wore sunglasses to prevent any eye irritation and went thru about twenty old t-shirts. All in all, took about an hour including the 30 minutes I took to let the liquid wrench soak in.
Old Aug 12, 2008 | 12:04 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Thank you scramby I was having troble finding my fuel filter tonight. then again I was looking for it about 20mins ago(12:40 am ) in a not too well lit garage ( apt complex) but at least i got my rear sway bar back on
Old Aug 12, 2008 | 02:22 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
1986 IROC-Z 305 TPI
scramby. Your detailed explanation of what you did is very helpful to DIY guys like me.
Old Aug 12, 2008 | 03:17 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
...apparently sarcasm is hard to pick up on in the forums lol
Old Aug 12, 2008 | 03:21 AM
webeeZ28's Avatar
Engine: 5.7 350 B2L
Now that's funny
Old Aug 12, 2008 | 09:24 AM
Scramby's Avatar
Car: 1986 IROC-Z
Axle/Gears: 2.73?
Glad I could help.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
92camaroJoe
Aug 13, 2015 06:07 AM
