help me find coolent leak!
Old Aug 12, 2008 | 08:29 AM
ty85iroc's Avatar
have an 85 iroc 305 tpi. came to park it in the driveway after a car show and there was a good coolent leak coming from the pass. side dripping off the starter. so put the car in the garage for a week then jacked the car up and started to look for the leak bone dry everywhere, checked all hoses. looks like i lost about a quart of coolent. checked the oil it was fine ( no coolent ) so i put my coolent pressure tester on the system and found no leaks and the pressure never went down????? couple hours later i go back out determined to find this leak and when i put pressure to it again i found a leak on the bottom pass. side of the firewall so i thought heater core! put in a new heater core and idled it for 40 mins no leak problem solved?! NO i drove it to town to get gas and was leaking ing the same damn spot..
heater core is not leaking checked it again also the heater core hoses are tight and not leaking..
when it does leak it seems to start leaking when the engine is cut off, it leaks about a quart then stops..
also NO intake leaks and oil looks clean just keeps dripping from that little flange towards bottom of fire wall pass side.. thanks
Old Aug 12, 2008 | 08:57 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: help me find coolent leak!
did you check the hose that goes straight down from the heatercore into the back of the engine? Not the one that goes in right next to the distributor, but the other one that comes directly from the heatercore and goes straight down like 6 inches.
Old Aug 12, 2008 | 09:00 AM
ty85iroc's Avatar
looks rusty but not leaking
Old Aug 12, 2008 | 09:07 AM
Frosty209's Avatar
Car: 1984 Chevy Camaro Z28
Engine: 305 4BBL.
Transmission: 700rt
better to change it then leave it rusty like that..and make sure hoses arent to tight because it can leave stress marks and make it a weaker connection. To tight isnt good.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
mike_c
Aug 27, 2015 04:32 PM
formula_novice
Aug 18, 2015 08:48 PM
