smog pump pulley delete
Old Aug 19, 2008 | 09:04 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
I just have a question about the smog pump. Since the headers I have don't have air attachments, is a new pump delete pulley necessary or can i just take out the pump and belt out? I see hawks sells one.
thanks for looking
Old Aug 20, 2008 | 06:13 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: smog pump pulley delete
there is a A.I.R./ smog pump removal article on this forum . check the tech articles . requires just removal of items , different belt , different belt routing . works great , i did mine several years ago . never a problem . good luck .
Old Aug 20, 2008 | 07:50 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Okay thanks. Less clutter the easier it is for me to work on my car.
Old Aug 20, 2008 | 08:14 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
It really is that simple. Just make sure to double check when you are done that everything is rotating the correct way.
Old Aug 20, 2008 | 10:59 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Very easy to do. Did mine two years ago. The belt will be a little shorter. If you need a dayco # let me know assuming you have air conditioning. The routing of the belt is different, but straight forward.
Old Aug 20, 2008 | 11:58 AM
dctrumpet's Avatar
Here is my setup without the smog pump and without the delete pulley. The Dayco part # is 5060970 for that setup. I believe if you use the delete pulley then it should take the stock belt. Not sure on that one. Been two years since i did this, lol!!!
Attached Thumbnails smog pump pulley delete-img00318.jpg   smog pump pulley delete-img00319.jpg   smog pump pulley delete-img00320.jpg
Old Aug 20, 2008 | 04:06 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Hey two years sounds good to me. That means no problems! Yeah I have a no belt on my ac right now. So should I just buy the belt with the number you provided me or do I need another one because my AC isn't hooked up? thanks guys. can't wait to get this done.
Old Aug 20, 2008 | 04:33 PM
dctrumpet's Avatar
Not sure how you would run the belt if you have no a/c hooked up. It obviously would be considerably smaller and I would place a delete pulley in place of the a/c.
Here is a very very crude drawing of the setup i have. It is in Word format.
GOOD LUCK!!!!!
File Type: doc
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
Street Lethal
Aug 12, 2015 11:33 AM
