"fuelie" heads??
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
"fuelie" heads??
as title reads my friend has "fuelie" heads.. came off a 327 selling for 100 bucks. fully assembled, he says there are no holes on the heads for mounting the alternator.. my question is .. if they sell an adapter to fit these style heads on a later engine.. that requires holes on the heads for mounting the alternator..
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: "fuelie" heads??
Pass on them. Not good heads for your use - not that you can use them anyway due to the lack of accessory holes.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
They really aren't worth the hassle... They can be made to make some power but they are ancient. The only factory GM heads I'd buy are Vortecs.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
u can have wholes drilled and taped on them but like said b4 pass on them they are no good for u. now next item up for business WOW is that the crowd u hang with a honda and a ford? lmao
i
i Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
30+ year old heads with 30+ year old technology. There are far better modern factory and aftermarket heads which can out perform those old heads for a lot less money and they'll be a better casting right out of the box.
Leave those old heads for someone who needs them because they have to run correct casting numbered heads. You can probably pick up a good set of aluminum heads for less than what it will cost to get those heads up to scratch. Even if they were given to you, they're not worth it unless someone has already spent a lot of money doing them up.
thanks alot for the input guys/gals..
i appreciate it.. i was just trying to look for something other than my stock heads.
if i could modify my current heads up to aftermarket standards i could do that.. i just dont want to be spending 700 dollars per head.
ill pass on them, you all know what you are talking about.
as for igotta355z28 yeah that IS the crowd i hang with lol .
there are like NO other third gens here in southplainfield nj i could roll with..
plus they are 2 of my best friends so youll have to excuse the one in the focus cuz he dont know better.. and the civic.. well.. i had one .so i cant say nothing about it, i still love my honda.. but just as much as my camaro
Car: 1982 Trans-Am
Port up your 416 heads. I put about $400 into my set. They run pretty good on my 350.
hmm. port match them up with the gasket... i kinda dont want to mess with the intake side.. im afraid i will polish it up a little tooo much and screw with "atomization".. so i think ill just port match the exhaust side. and polish it up real nice..
thanks for the advice you are all very knowledgeable.. this is a great forum to be a part of...
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Car: 87 Z28
Engine: 406 SBC
Axle/Gears: 4:10's,Eaton Posi
Yep,pretty terrible heads those "fuelie" heads.
Such junk,they even forgot to put accessory holes in them!
But if anyone has a pair,I will buy them as long as they are cheap!
And if anyone has a good 4 bolt main 400 block,better sell it too me too!
Everyone knows they are way weaker than the 2 bolt main blocks and it will just crack.
hehe.
hehe.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
