CAMARO STARTERS--THROW ME A BONE!
Old Sep 11, 2008 | 08:29 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
Brothers, throw me a bone... I am ready to replace my factory starter and need some recomendations.
I have been thinking of going with a powermaster. I even called SUmmit racing to inquiry abou the Power Master 9100. The tech man ask me about the bolt pattern.. (if they are staggered -- if both botls have the same distance from the bellhousing) and about the Flywheel
In truth I could not answer this questions. My car came with an LG-4 engine that I swapped in favor of a 355 engine (CR 10.5:1). The swap was easy and I use most the the parts from the LG-4 (including LG-4 Starter, Bell housing, Flywheel, etc)
The starter has always been a weak, but it work until now, its dead... Good time to get a MUSCLE UP starter.
I dont care about the weight of the started, and care about bolt on installation, power, and reliability. My car has the Edelbrock TES headers.
Any suggestions?
throw me a bone brothers!!!
Old Sep 12, 2008 | 12:04 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: CAMARO STARTERS--THROW ME A BONE!
db-starter-alternator.com i got my high torque starter shipped to me for 63 bux well worth it. itll turn over 18:1 no problem
Old Sep 12, 2008 | 12:16 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
THanks, Went to the site. They look alot like the PowerMaster, but way cheaper. I wonder if is the same or better quality. How long you got your starter from DB?
DOes any body has experience with the PowerMaster Alternators?
Old Sep 12, 2008 | 01:12 PM
Damon's Avatar
I have a Powermaster starter on several vehicles- no problems to report.
You can buy starters off ebay in the $50-60 range but they're rebuilds. Powermaster or GMPP is all new parts, which is probably the price difference.
Stock LG4 parts are the smaller 153 tooth flexplate/flywheel. Straight bolt pattern. A popular bolt-in upgrade is a later LT1 gear reduction mini starter (new or rebuilt). Much smaller and lighter than the stock full size starter, but with greater cranking force.
Old Sep 12, 2008 | 07:52 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
Thanks for the info. There so many choices on the starters. The one listed on the DB website (from above reply to thread) look the same as the powermaster. I just want something that last. Eventhough I re-use the LG-4 Flywheel and Bell Housing, the engine is a 355 10.5:1 Compression Ratio. and I do have headers.
I also heard about the NIPODENSE STARTERS... Hmmm
Old Sep 12, 2008 | 09:17 PM
Damon's Avatar
Just thought I'd also throw in that the GMPP high torque gear reduction mini starter I have on my Malibu (383 stroker with the larger diameter 168 tooth flexplate, so not directly comparable) has been moved from engine to engine for 10 years. It's a rock-solid piece. Same one that comes with the GMPP 502 and 572 big blocks (small block and big block staters interchange). And it should be considering I paid $180 for it way back then.
It looks externally like the $60 rebuilds they offer on e-bay. I doubt a rebuild would have lasted through the abuse I've thrown at this starter. HOWEVER, I could have replaced it 3 times with a cheap rebuild for the money I spent.
You pays your money and your takes your pick.
Old Sep 13, 2008 | 07:41 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
Ok, so I have concluded that my starter solenoid if bad... so I decided to take it off... and then come the problem.. DAMM headers are on the way to take the starter so I have to actually dismount the Y-pipe from the headers to take the starter out... MAN!!!! I am FURIOUS.... Sometimes, Sometimes I wish I never got headers...
Besides my ranting, I have confirmed that my bolt pattern is not staggered. I will purchase a Power Master Startedr.... Any suggestions?
Old Sep 13, 2008 | 07:50 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
What about the Powermaster 9600 MasterTorque Chevy Starter? ANy exeriences? Look small enough that I would not have to take the Y-pipe out in order to take the starter out (in the future).
Old Sep 14, 2008 | 10:54 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
O.K., Ijust took the old starter out withoug having to remove the Y Piper of the headers... Took the solenoid out first, and the it managed to squezze out... Good....
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
sreZ28
Aug 14, 2015 07:48 PM
