pushrod length
Old Sep 13, 2008 | 02:15 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
pushrod length
i have a 92 trans am with 305 tpi i have some 327 camaro double hump heads that are all original. i want to install with an intake and carb my question is will the stock pushrods work with the new heads. or will i have to buy new pushrods?
Old Sep 13, 2008 | 02:32 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: pushrod length
yes they will work, Youll only need to change them if you swaping cams.
Old Sep 13, 2008 | 02:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: pushrod length
For the most part, stock pushrods will work but proper valve train geometry should always be checked when mixing and matching parts.
Old Sep 13, 2008 | 03:10 PM
92whiteta's Avatar
Engine: 355
Re: pushrod length
ok thank you for the quick replies
Old Sep 15, 2008 | 08:53 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: pushrod length
Same heads I'm running on my 350. Don't forget the lead substitute with every fillup or you'll eat up the valve seats...
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
