WHY IS MY CAR BOGGING OFF THE LINE?
Old Sep 13, 2008 | 10:08 PM
lbman0007's Avatar
Car: 1986 Chev Camaro
Transmission: Th350
Axle/Gears: 10 bolt 3.23 posi
I was on here a while back with the low oil pressure problem . Fixed it with the 50w oil and lucas . now just added used msd 6a and it boggs taking off slow or fast . What can cause this compression is 11.5:1 runnin pump gas plus with octane booster . Had to use 87 because hurricane and no premium available. Any advice will be good.
Old Sep 13, 2008 | 10:54 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: WHY IS MY CAR BOGGING OFF THE LINE?
Straight 50w might be a sighn of the problem that is some thick *** oil, have you done a compresion check? were was the oil leaking from?
Old Sep 14, 2008 | 11:45 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
50W for an oil pressure problem is no "fix" by any stretch.
A bog can have many causes, lean mix is probably the most common.
Old Sep 14, 2008 | 01:36 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Mine bogged off the line when I went back to the factorinstall squirters. I went from 28 to 45 front and 45 rear squirters amd solved that issue.
Old Sep 14, 2008 | 08:55 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Originally Posted by lbman0007
Fixed it with the 50w oil and lucas.
that is definitely not a solution to the oil pressure issue.
i think it is a tuning issue or you need to make an adjustment with the new ignition.
Old Sep 14, 2008 | 10:06 PM
lbman0007's Avatar
Transmission: Th350
I think bad clearances is the oil pressure issue . but now its 45 psi cold and 25 psi hot . just hate the bogging . it just started after i installed the msd .
does it have any type of adjustments on the ignition box. its one of the older msd 6btm boxes.
Old Sep 14, 2008 | 10:12 PM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
I had a similar problem after installing my msd 6A and ended up changing out the hei coil and control module... MSD is great as long as the rest of the ignition system will handle it... may be something to think about...
Old Sep 14, 2008 | 10:22 PM
lbman0007's Avatar
Transmission: Th350
I have an Accell super coil hei style but i removed the module to plug up the bypass cable . Also, i have a newer Mallory hyfire 6a i can try . Do those msd boxes go out often ?
Old Sep 15, 2008 | 11:17 AM
the only trouble I've seen with msd is when they are wired up wrong... I worked in auto parts for 6 years... seen a few come back to the store for that...
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
