What Part is This?
Old Sep 16, 2008 | 12:34 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
What Part is This?
I know I'm going to get flamed for this, but I have no idea what these things are and don't know how to find out.
Old Sep 16, 2008 | 02:04 AM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: What Part is This?
ESC module
Old Sep 16, 2008 | 09:33 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
ignition module
Old Sep 16, 2008 | 09:36 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Originally Posted by squirted1
ignition module
Old Sep 2, 2009 | 03:43 PM
Car: 1985 Z28
I'm bringing this thread back because I believe my ESC may be going bad.
Is the ignition module and the ESC one in the same or are they two different parts? What is the function of the parts in the picture?
Old Sep 2, 2009 | 03:58 PM
Twin_Turbo's Avatar
The ESC is part of the ignition module. NON ESC (non comp. controlled) have fewer pinouts.
The ignition module itself can be seen as the switching relay that grounds the coil to collapse the field and deliver the secondary voltage to the wires & plugs.
Old Sep 2, 2009 | 04:28 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Some auto part stores can actually test these, but you may have to search around. I know my local Advance Auto has a module tester, but nobody in the store knows what it is or how its used.....
Old Sep 2, 2009 | 04:31 PM
Car: 1985 Z28
So, the ignition module is what is shown in the picture? Would it be the right one for my car, and I read that it is located under the distributor cap.
Also, I read the esc module is located on the drivers side firewall.
Old Sep 3, 2009 | 09:54 PM
Pat Hall's Avatar
Also, I read the ESC module is located on the drivers side firewall.
Correct, the esc module on your car is located behind the brake booster on the firewall. 90-up cars with speed density TPI had the ESC function built into the ECM, but 89-older has it separate on the firewall.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
