Crossfire intake questions
Old Sep 20, 2008 | 10:09 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I came across a crossfire intake locally that the owner said came of a Vette. My knowledge of these intakes is slim to none.
How do you tell the difference between a F-body crossfire intake and a Vette crossfire intake?
Thx. in advance.
Old Sep 20, 2008 | 01:27 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: Crossfire intake questions
I don't think there is a difference but if you are looking for a camaro one I havea setup I am looking to get rid of.
Old Sep 20, 2008 | 02:23 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Dokken10 the CFI intakes are the same for the F-Body's LU5 305 and the Corvette's (Y-Body) L83 350. The lids are the same for all years as far as I know. There are two versions of the intake base.
The first version has casting (P/N) 14031372. This one was used on the '82 Corvette and the '82-'83 F-Body.
The second version has a casting (P/N) 14057017. This one was used on the '84 Corvette and some late production '83 F-Bodys (mine has it - she was built 3rd week of June).
The only difference between the two is the '017 base has balance holes in the runners. These are supposed to equalize flow pulses but there is still some question as to them being beneficial. Both benefit greatly from port matching as they are 2/3 the head ports smoothing inner runners and clean up of casting flash.
I hope this helps you.
Old Sep 20, 2008 | 02:36 PM
Dokken10's Avatar
Car: 91 Formula
Thx. coolram62
This intake also comes with the TB.
Would the TB and injectors be the same from a F-body and the Vette?
Old Sep 20, 2008 | 07:00 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by Dokken10
Thx. coolram62
TB's might be, but the injectors aren't, as the Vette ceasefire motor was a 5.7L, where the F-cars had a 5.0 - they used a smaller injector on the 5.0
Old Sep 20, 2008 | 07:11 PM
Dokken10's Avatar
Car: 91 Formula
I thought so, anyway to tell the difference between the 5.0 and 5.7 injectors?
Old Sep 21, 2008 | 11:19 AM
coolram62's Avatar
Engine: LU5 305 CFI
Dokken10 as Air_Adam noted the TBI assemblys are the same for both the LU5 305 and the L83 350 but the injectors are different. These are the P/N for the injectors for both motors provided they haven't been swapped out (ie:bigger injectors). The numbers are stamped and visible on the top of the injector under the pigtail connector.
'82-'83 LU5 305 Rear INJ P/N 5233765 , Color Code - Green
Front INJ P/N 5234255 , Color Code - Purple
82 & '84 L83 350 Rear INJ P/N 5233770 , Color Code - Yellow
Front INJ P/N 5233775 , Color Code - Brown
The intakes have potential but it does take time patience and a lot of work to get them to flow well. On the LU5 the other restriction is the exhaust as it was shared with the LG4.
Old Sep 21, 2008 | 11:37 AM
Dokken10's Avatar
Car: 91 Formula
I appreciate all this info from everyone, especially coolram62.
I'm not into these intakes but I will probably buy it and sell it. I know these are getting harder to find and I hate to see good parts thrown away like this intake.
Thanks again everyone.
Old Sep 21, 2008 | 12:09 PM
Dokken10's Avatar
Car: 91 Formula
I called the guy who has it and the base is 14057017 and the injectors are the 5233770 and 5233775.
So it came off a 84 Vette.
Old Sep 21, 2008 | 06:25 PM
Air_Adam's Avatar
Might be worthwhile just to hold onto it for awhile if you can get it cheap - they used it only for '82-83 in the F-cars, and '82-84 (was no '83) Corvette, so they are fairly rare. Could become a good collector/restoration part in a few years. Might be worth something, especially with the Corvette specific parts and if its complete.
Old Sep 21, 2008 | 06:32 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I think it'd be interesting to modify one of those to use two 305/350 TBI's and then port the crap out of it. Could make some power.
Old Sep 21, 2008 | 06:42 PM
Dokken10's Avatar
Car: 91 Formula
I went and bought it today, I'm going to put it up on Ebay with a high reserve and see what happens.
I have no idea what these are worth.
Old Sep 21, 2008 | 08:00 PM
coolram62's Avatar
Engine: LU5 305 CFI
Dokken you may also try the Crossfire injection Forum
http://www.crossfire.homeip.net/
http://forums.corvetteforum.com/index.php?
Someone there may need an intake assembly. One Ebay you will find a very large price range when it comes to CFI manifold assemblys. I've paid between $25 to $50 plus shipping for the 3 manifold assemblys I bought off there the past four years. Do research what is currently on Ebay to get an idea for your startinf price.
Saabster these manifolds respond extremely well to porting. Biggest reason is the mismatch between the heads and intake. Smoothing the runners and cleaning casting flash really make a difference - the foundry castings were poor compared to most others. The TBI's themselves can be ported for larger butterflies which aslso increase flow dramaticaly.
Old Sep 21, 2008 | 08:20 PM
Dokken10's Avatar
Car: 91 Formula
Good thing I only paid $20 for it. They aren't worth anything.
Old Sep 21, 2008 | 09:30 PM
coolram62's Avatar
Engine: LU5 305 CFI
Dokken it's been a couple years since I bought an intake (2 were complete with TBI's and linkage 1 was just a base for my porting practice). The price has gone up some depending on how complete they are. If you could find a CFI harness/computor reasonably priced and do a combo package you could get a good deal more. It's amazing that some bring good money and some don't - it usually falls into 2 categories either someone doing a resto that needs a setup that's missing or someone needing a intake to port/modify.
Old Sep 21, 2008 | 09:52 PM
Dokken10's Avatar
Car: 91 Formula
coolram62, I noticed that on Ebay. The range is from about $50 -$250.
I might be going back to work for Gulfstream in Savannah and we might be neighbors. I hate Atlanta and would love to move back to Savannah and the beach.
I listed it on Ebay about a hour ago, so we will see what happens.
I have a real nice 84 Z28 roller, are you looking for anything for your 83?
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
3rdgenparts
Aug 6, 2015 09:03 AM
