needing some gasket info please
Old Sep 27, 2008 | 07:01 PM
toddyman88's Avatar
Installing my new Edelbrock hi-flow intake on the 91 rs 305. I bought the Felpro set number MS93035-1 for all the gaskets. Looking over the instructions that came with the intake it says not to use perma-torque gaskets. Are these felpro blue ones prema-torque? If so, why cant I use them? What should I use instead? Can I use these and be ok?
Appricate the help.
Gordon
Old Sep 27, 2008 | 10:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The part number you listed is for the TPI application. You have TBI.
Old Sep 27, 2008 | 11:13 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: needing some gasket info please
my buddy got a top end gasket kit for my 'maro way back in the day. he swore up and down that it was tbi. I didn't really use half of em' anyways though.. oh, and yeah the wire pack is definately not the baro sensor ha!
Old Sep 28, 2008 | 08:10 AM
toddyman88's Avatar
No, My 91 is very much TPI. My 82 however was TBI. So does anyone know about my gasket delema??
Old Sep 29, 2008 | 12:20 AM
five7kid's Avatar
If it's an RS, it isn't TPI unless it was converted from TBI to TPI.
'82 EFI was Crossfire. A TB system, but not the same as what is commonly called TBI.
Old Sep 29, 2008 | 07:09 AM
toddyman88's Avatar
I thought that all 91's reguardless of trim (RS or Z-28) were all TPI from the factory. It is defenatley TPI, air tubes off the upper intake plenum and all.
Old Sep 29, 2008 | 09:34 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Mines a TBI so.
Old Sep 29, 2008 | 01:01 PM
five7kid's Avatar
https://www.thirdgen.org/1991-chevy-camaro
What's the 8th character of your VIN?
Old Sep 29, 2008 | 04:34 PM
toddyman88's Avatar
Vin # is 1G1FP23F2ML173209 So the 8th didgit would be F.
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
