oil pouring out of the engine
Old Oct 1, 2008 | 07:15 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
I recently replaced my OPSU with a mechanical gauge and now everytime I start the car oil pours out of the back of the engine.. I removed the flexplate shield ( auto ) and the flywheel and torque converter were covered in oil. I removed the oil filter adapter plate when I removed the OPSU ( to make sure the threading was still in tact ) and there was a paper gasket. Upon checking all the parts stores AND the local Chevrolet dealership they ALL claimed that there was no gasket put there unless there was a stock oil cooler that was removed and it seems that this problem hasnt started until I put the adapter back on ( drove the car for 1 day and all was fine ) however for some reason the car runs 50psi at initial idle and over 60 when driving. any ideas?
Old Oct 1, 2008 | 09:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: oil pouring out of the engine
If the flywheel and converter are covered in oil, I don't see how it would get there from the oil filter adapter...? I'd be much more suspicious of either the oil gallery fitting on the left (drvers) side of the distributor on the block, or one of the plugs around the cam plug behind the flywheel. Rear main seals are notorious for leaks too, but thats not under pressure, so it shouldn't just **** out like you are describing.
Old Oct 1, 2008 | 11:27 PM
87IROC92RS's Avatar
Car: 87 IROC
yeah I didnt figure the rear main would see the pressure and im trying to avoid dropping the trans or lifting the motor to see where its leaking from but it has to be coming from the upper end of the block. As soon as I start the car it pisses out but when I turn it back off it stops
Old Oct 2, 2008 | 02:21 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Did you replace the paper gasket?Yuo put on an oil pressure gauge.The oil is coming out under pressure.Sure you didnt miss something.Pinched a hole in the line maybe
Old Oct 2, 2008 | 11:54 AM
87IROC92RS's Avatar
Car: 87 IROC
according to gm and every parts place I went to there is no such gasket that goes on there and as far as the capilary tubing I checked it for leaks and nothing. its definitely coming from the back of the block
Old Oct 2, 2008 | 08:12 PM
87IROC92RS's Avatar
Car: 87 IROC
lol it does have **** leakage but I couldnt find a butthole. Im pretty positive that the rear main split and is spraying oil out but come tomorrow the car will be in the garage and the motor will be lifted and seperated from the tranny so I WILL find out where this leak is coming from
Old Oct 4, 2008 | 04:15 PM
87IROC92RS's Avatar
Car: 87 IROC
turns out there IS a gasket that goes into that oil adapter. I started the car with it raised on stands started it and watched it come out between the oil filter and the block. Ordered a new adapter WITH the gasket from summit along with a new 3 Inch universal put together exhaust system so I should be back on the road.
Old Oct 4, 2008 | 04:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
By "adapter" do you mean the oil cooler?
Old Oct 4, 2008 | 04:26 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Goes to show what the parts house guys and even your average counter or phone guy at gm knows.I love it when they tell me something doesnt exsist or you cant get something.
Old Oct 4, 2008 | 07:12 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
That would be my guess. There is in fact no seal on the filter adapter that bolts to the block, there is no reason for it to have one, the oil filter gasket itself seals to the block.
Old Oct 4, 2008 | 07:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, the oil filter adapter doesn't need a seal. The oil cooler needs a seal.
Old Oct 5, 2008 | 12:49 PM
87IROC92RS's Avatar
Car: 87 IROC
well the only answer for why its leaking would be when I pulled the part off that the oil filter screws onto ( be it adapter, cooler whatever ) there was a gasket in there and it never leaked till I removed it put it back together and it sprays out. I knw the part has a little spring in it then a cap with a channel in the top where it seems its spraying in that direction ( towards the block ) and on the other side where that spring is, is a little screen
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
