can I use a hyd cam in a roller block
Old Oct 2, 2008 | 08:24 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Hi, I am looking to use a hyd. cam in a 1990 roller block..I will use roller lifters but looking to use a hyd cam. Do I need a different thrust place with the hyd cam?
Thanks in advance
Old Oct 2, 2008 | 08:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: can I use a hyd cam in a roller block
No, factory cams are hydraulic rollers.
Old Oct 2, 2008 | 08:40 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
no I cant use the cam or no I dont need a new thrust plate?
Old Oct 2, 2008 | 08:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No you don't need new parts if you use an OE-style cam.
Old Oct 2, 2008 | 08:53 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
so it does not have to be a roller cam?
thanks...I was puzzled because in the catalog Im looking at from elgin industries has a different section for roller cams and it references using the stock thrust plate only for the roller cams...Im confused as always.
Thanks for any help
Old Oct 2, 2008 | 09:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are two types of roller cams... original-equipment-roller-type and retrofit-roller type.
Original-equipment-roller-type cams must be used in factory-roller blocks with the original-equipment-type retainer plate and matching timing set. They can't be used in non-roller blocks.
Retrofit-roller cams can be used in any block, provided that they're used with the old-style non-roller timing set and a thrust button or thrust bearing.
Old Oct 2, 2008 | 10:37 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
if you are asking if you can run a hydraulic flat tappet cam in a roller block, the answer is yes. GM actually did that with some of the late 80's, early 90's truck blocks.
Old Oct 3, 2008 | 06:04 AM
Damon's Avatar
But if you're asking if you can use a hydraulic flat tappet cam in that block with your original roller lifters, no, you can't do that.
Old Oct 3, 2008 | 09:37 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Boy, what a mess... ok, 4 types of cams:
solid flat tappet
hydraulic roller
solid roller
Notice how there are TWO hydraulic cams? Ok, now that we're clear on that.. You have a hydraulic ROLLER cam factory in that block (or it should). Do you want to run a hydraulic FLAT TAPPET ? Key words here are roller or FLAT TAPPET. They're all hydraulic. Solids are more of a race only style of part, not the everyday norm sorta thing.
If you want to downgrade to a flat tappet, you need matching lifters and pushrods, but yes you can do it. I'd recommend you stick with roller stuff though....
Old Oct 3, 2008 | 01:57 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Hey SONIX thanks for the clarification...I think I am going to use roller cam and lifters to avoid having to take it apart again if something doesnt fit right or seems right but isnt if you know what i mean....Reinventing the wheel is something Im not up for and taking it apart again isnt high on my list of weekend activities....thanks again everyone.
Buzzman1
Old Nov 7, 2010 | 06:09 PM
AMERICAN METAL's Avatar
Car: 1989 Camaro iroc-z
Engine: 355, patriot 190cc, comp 280h
Transmission: 700r4, 3k tall, tci constant press
Axle/Gears: 10 bolt /4.10 GM POSI
If one converted would you have to get different length tappet pushrods then on a engine taht was a tappet engine stock? Thanks for the wisdom.
Old Nov 7, 2010 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're all "tappet engines"... a tappet is a lifter.
If you change between factory roller, retro roller or flat, the pushrod length will change.
Old Nov 7, 2010 | 10:16 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I think he was asking if he could use roller tappets on a flat tappet cam,
that's a HUGE no no. Sonic got it.
I would NEVER move from roller to flat tappet.
Metal, Yes.
ziggy89
Sep 7, 2016 08:12 AM
drdave88
Feb 16, 2013 12:49 PM
1983sc
Jul 30, 2007 10:30 PM
ChrisFormula355
Feb 24, 2004 09:33 PM
Mike '91 Z28
Sep 12, 2000 07:47 AM
