car will turn over and barley fire if at all
Old Oct 4, 2008 | 12:46 AM
lukeylouk's Avatar
Car: 1988 camaro rs
Engine: 305 v8
okay so my 305 v8 "Q-jet" is allmost on the home strech to running. i put in a new carb, battery, alternater, fuel lines, break lines, new battery, new spark plugs, AND NOW when i turn over the engine it will turn over as normal but it dosent like to fire, if i floor the pedal it will spudder and barley run and die out when i let go of the gas, the gas is getting to the carb, i know i have timing issues. so does this sound like a timing issue? or anything eles.
plus ive never timed a engine before if anyone knows a step by step video or website it would be greatly appreitiated
**edit**
is it possible that i flooded it to? is this what the engine could do when u flood it?
Old Oct 4, 2008 | 11:42 PM
lukeylouk's Avatar
Car: 1988 camaro rs
Engine: 305 v8
Re: car will turn over and barley fire if at all
guys? any1? any help would be great
Old Oct 4, 2008 | 11:59 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
its timing. you need to turn the distributer until it gets better. loosed the crows foot holding the distributor down to the manifold. turn the dist a very little bit at a time and crank it. it sounds like its too retarded and it needs to be advanced, once you get it to dtay running you can slowly turn the dist til it sounds the smoothest.
Old Oct 5, 2008 | 01:22 AM
lukeylouk's Avatar
Car: 1988 camaro rs
Engine: 305 v8
so should i pump the gas at all? because ive been doing that and i get a sneaking suspestion its a bad idea
9192camaro
16
Feb 3, 2019 12:21 AM
B_Dubya
Aug 26, 2015 05:09 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
