Stupid question....
Old Oct 8, 2008 | 11:05 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Stupid question....
Ok, I am going to install a vacuum gauge on my 91 Camaro, and I have a REALLY STUPID QUESTION!
What is involved in hooking this up? Just a hose from the TB to the gauge, and an electrically hot wire if I want it to light up after dark? Doesnt the car have a vacuum sending unit? (Speed density TBI....)
Part
Can I install one of these and then tap into the wire that goes from the vacuum sending unit to the computer?
Old Oct 8, 2008 | 11:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stupid question....
The electrical signal from the MAP sensor isn't necessarily compatible with what the gauge expects.
Old Oct 8, 2008 | 11:12 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Then would I be better off with a non electrical?
I have heard those are not drag race legal.
The only sending unit i found is $64 dollars, way out of my price range....
Old Oct 8, 2008 | 11:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A mechanical gauge will probably be cheaper. There are no racing legality problems.
Old Oct 8, 2008 | 11:25 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
part
So this would suit my needs? Just plug a vacuum line into the back?
Old Oct 8, 2008 | 11:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Something like that should be fine.
Old Oct 8, 2008 | 11:35 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Your awesome, thanks for your help.
One last stupid question, I just take a vacuum line from the engine to the gauge?
Old Oct 8, 2008 | 11:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much, the gauge probably comes with tubing, you'll just need to adapt it to a convenient vacuum source.
Old Oct 8, 2008 | 11:57 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Thanks!
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
