89 TPI, Problems Staying ON!!!!!!!
Old Oct 14, 2008 | 02:45 PM
coyote452002's Avatar
I bought a 1991 Z-28 Camaro convertible with out the ECM, ECM wiring, engine, or transmission. I installed the ECM, ECM wiring, engine and transmission from a 89 camaro Z28 ( the body was all torn to **** ). My problem is that IT STARTS LIKE A MATCH AND HAS NO PROBLEM STYING ON, BUT WHEN I PRESS THE GAS PEDAL IT TURNS OFF. It backfires with a little open throttle and when you open it it just shuts off, Then i have no problem turning it on again. HERE IS WHAT I HAVE DONE TO TRY AND FIX THE PROBLEM-----Replaced the MAF sensor, but stills shows trouble code 34, replaced the fuel pump, replaced the cap and rotor along with the SP and SPW, replaced the battery. CAN ANY ONE PLEASE HELP!!!!!!!!!!!!!!!!!
Old Oct 14, 2008 | 05:32 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 89 TPI, Problems Staying ON!!!!!!!
Time to troubleshoot. This thread may help:
https://www.thirdgen.org/forums/tpi/...value-not.html
Ghettobird52
Jul 5, 2024 11:18 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
Sherpajames
Aug 7, 2015 06:56 PM
