how to build engine for dummies?
Old Oct 17, 2008 | 08:44 PM
ace74's Avatar
just wondering if there is something online i can read or watch that shows how to put together an engine and get it to run lol ive never done it figured it would be usefull lol
Old Oct 17, 2008 | 08:59 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: how to build engine for dummies?
i would start on a stock rebuild and nothing that will cost you lots of money cuz you dont wanna have to do it again.
i just paid a shop 2500$ to build and dyno me a blown 489 stroker.
Old Oct 17, 2008 | 09:07 PM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
There is a book called how to build a small block chevy.
It will give you tip on how to do anything with a low budget of no more than $4000 and have a motor that wil make over 600 HP.
The most complex thing about building a motor, is clearances,tolerances of bearings and the parts you use. If you have the parts situated and they wil handle the power you want to make then your golden. I myslef have my machine shop get the block ready, as far as machining and what not goes, installing bearings etc. Then I put the motor together myself. Its not hard. You just have to make sure you have all the correct torque specs and sequences of how to tighten everything down so its right.
Old Oct 17, 2008 | 09:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
But not both at the same time.
Old Oct 18, 2008 | 08:05 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
building an engine is one thing, having it last is another. My best advice, dont be afraid to ask questions, and do as much research as you possibly can. Building a SBC or BBC are one of the easyiest engines to build.
Old Oct 19, 2008 | 08:31 PM
ace74's Avatar
cool thanks yall,
yeah when i move into a place that has a garage im thinking about taking my engine out and breaking it down and puting it back together just to get some basic how to on it, my buddy know how to fix everything if i mess it up lol so im good..
Old Oct 19, 2008 | 10:25 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
There is more info on this site than you will ever need. I built my 385 entirely from searching this site and posting questions. I have run into a few hiccups but TGO came through again and my baby is running nicely now.
Old Oct 20, 2008 | 03:49 PM
kevinc's Avatar
Car: 1982 Z28
Estimate you'll spend around $600 or so on engine components including pistons, bearings, rings, gaskets + seals, new cam, timing set.
If you're going to try a first-time rebuild without a manual and precision tools, there's an easier way to accomplish the same outcome...
...just take a match and burn the $600 cash.
Old Oct 20, 2008 | 04:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
David Vizards "how to rebuild the SBC" is a great book.
He also has a few hotrod books. Somewhat dated, but the principals are solid... you don't get HP from red plug wires, but from cylinder head flow etc. Good info. "how to hotrod the SBC" is his other really good book IMHO. Lots of good pictures and whatnot. ie how to put your piston rings in right side up... make sure you put in the plug below the #5 main cap, how to put in your freeze plugs so they don't leak, etc etc.
Old Oct 20, 2008 | 04:37 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Search online for books by David Vizard. He has written several books on rebuilding/building up SBC's. I can't remember the exact name of the one I have, but its very thorough for a basic rebuild. Lots of pics so you know what he's talking about. I picked mine up on Ebay for about $30 with shipping.
EDIT: Sonix beat me to it. Damn you!!!
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
