Constant Blue Smoke
Constant Blue Smoke
I bought a GM Performance Parts 350ci Crate Motor from Jegs 2 years ago and put it in my 89 Camaro. The warranty has expired on the engine. The engine has less than 5000 miles on it and it is smoking really bad. It is like a blue/gray smoke. It smokes a little on idle whether it is warm or cold. The smoke seems to get worse as the car warms up. Mechanics are looking at it and saying "I don't know." So, I come to the experts (since I am far from one) and am looking for some help. If anyone has any ideas on what this could be, please let me know. Thanks.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Constant Blue Smoke
If it smokes all the time, it sounds like a piston ring.
Thanks for the quick response. That would be my luck. I was kind of guessing it was that but hoping it could be something else. Anyone else agree or disagree? I will take more suggestions so I do not have to take the engine apart. Thanks.
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
I got a feelin bud that they messed up somethin when they put that motor together. You are better off pullin it back out and checking everything. Besides a set of engine gaskets will run ya 50 bucks on ebay and puttin it back together takes about a day. takin it to a garage or shop will get expensive.
Car: 1983 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 Bolt 3.27 posi
it definitely sounds like piston ring, agreed with above about pulling it apart, better safe than sorry
Transmission: 4L80E/4L80E
Could be something simple like an improperly installed intake manifold gasket. Who installed the engine?
Valve stem seals and piston rings are the other choices. How does it run?
I installed it. I bought the crate motor and it was pretty straight forward. Just put on the manifold, carb, starter, etc. Not much I could have screwed up on to have this thing pour out smoke before 5000 miles. Its looking like I am going to have to put this thing away for the winter and get a fresh start in the spring. It's great having to rebuild a brand new engine. Thanks Jegs.
Keep the ideas coming. I still open to ideas. Thanks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
-pull the plugs, compare them, any of them look strange compared to the rest?
-buy a compression tester for $40. use it. See if it points to any one cylinder.
- pull the valve covers, anything look funny? missing valve seal, etc? Run it with the covers off, anything? look at the cylinder that had the dirtiest spark plug
either that or change your oil lol
Just messin with ya!
