How to tell if I have a 2 piece or 1 piece rear seal?
Old Oct 27, 2008 | 11:49 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Hey,
Well I found a donor for a 6 speed swap for my car, it is an lt1 car and I want to make sure I don't need that expensive flywheel. From searches I have found that they changed styles around 86? My car is an 87 but I have no way of telling when the motor was made, its converted to carb. I can tell you it has a short water pump on it, and I put crane roller rockers on it. If either of that helps, I don't want to tear into in to find out lol.
Old Oct 27, 2008 | 11:54 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: How to tell if I have a 2 piece or 1 piece rear seal?
all i can tell yo uis that 87 and up blocks are 1 pc rear mains. you will have to check the casting number on the block.
Old Oct 28, 2008 | 10:35 AM
Guest
Guest
Posts: n/a
86 and up are 1 piece rear main.
Look under the car at the back of the oil pan where the rear seal is. If you see a big shiny aluminum thing back there its a 1 piece rear main.
Old Oct 28, 2008 | 07:12 PM
mbolte's Avatar
Car: 1987 Camaro
ok thanks, ill have to get under there and have a look, maybe take a picture just to be sure...
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
