Pontiac intake question
Old Oct 30, 2008 | 12:01 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I have a 1969 pontiac 350 with the stock intake in it, and a local junkyard just received an '81 trans am with a 403, with an edelbrock aluminum intake on it. Will this intake fit on my 350?
Old Oct 30, 2008 | 12:08 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Pontiac intake question
No, the 403 is an Olds motor.
Old Oct 30, 2008 | 12:19 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
you sure? the intake says 'pontiac edelbrock' on it.
Old Oct 30, 2008 | 12:21 PM
jv9999's Avatar
Engine: 5.7L/350
Then it's probably not a 403. Does it have the trademark Olds oil fill tube on the front? It might be a Pontiac 400. Take a look here: http://www.angelfire.com/fl4/pontiac...ds403infl.html
Old Oct 30, 2008 | 12:57 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I didn't think a 400 was available in '81. But then again i'm not that interested in 2nd gens. I'll have to go check it out again.
Old Oct 30, 2008 | 01:01 PM
jv9999's Avatar
Engine: 5.7L/350
What's in there today but not be what was in there 27 years ago.
Old Oct 31, 2008 | 01:04 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The Olds 403 also wasn't available in the Trans Am in '81. The last year for the 400+ cu.in. engines was 1979. The only Pontiac produced engine available in 1981 was the short deck 301 engine and no aftermarket companies ever tooled up an intake for that engine. It sounds like this junkyard car has had an engine swap.
If your '69 350 has a stock 4-bbl carb intake the Edelbrock intake is going to perform the same(if not worse) than the original. The pre-1975 factory intakes were about as optimised as it gets.
Old Oct 31, 2008 | 01:50 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
No, i have a 2bbl intake. So, since it is a pontiac intake, it isn't the original engine in the car... , which means the car most likely has a manifold that will work on my motor, or the motor is a 403. Guess I'll find out tomorrow.
1992 Trans Am
May 10, 2023 07:19 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
