Large Cap vs. Small Cap Dizzy Gear Sizes
Old Oct 31, 2008 | 09:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I am running a large cap dizzy with a hyd. roller cam and would like to change the dizzy gear to the factory 1991 melonized gear.
Are the large cap and small cap SBC distributor gear sizes the exact same?
Old Oct 31, 2008 | 10:02 PM
kcb37's Avatar
Re: Large Cap vs. Small Cap Dizzy Gear Sizes
Not sure about the sizes but you are generally better off with a harder gear.
Old Oct 31, 2008 | 10:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're all the same.
Old Oct 31, 2008 | 10:20 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks. What would be the difference between the .500 and .491 sizes I am seeing?
Old Oct 31, 2008 | 10:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Aftermarket distributors use a heavier .500" shaft.
Old Nov 1, 2008 | 01:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The small cap distributors need a tiny 0.427" shaft gear
Old Nov 1, 2008 | 03:01 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
So I'm assuming a stock GM melonized dizzy gear from say the 1991 model year probably won't fit an eBay special large cap dizzy?
Old Nov 1, 2008 | 04:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
91 is when they started using the small cap with the externally mounted coil. The small GM small cap is a computer controlled distributor with no weights or springs inside it.
A small shaft sized gear for a small cap won't fit on a large cap or aftermarket distributor. I suppose if you had a lathe or milling machine to accurately enlarge the hole, it would work. Cheaper to just buy the proper gear.
Old Nov 1, 2008 | 08:34 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
The Corvette only used the big dist. The new gm gears are support to melonized. I got a bronze one for my small dist. Crane makes them.
Old Nov 1, 2008 | 11:07 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
hmmm....thanks for the information Setphen.
So is there a GM melonized gear that would fit onto the large cap dizzy I have? I've found some on Summit's site but don't know my exact size....I still see the .500 and .491 sizes which I do not know the difference between.
I cannot justify 50+ bucks for a dizzy gear when the GM melonized one (that probably won't fit) is less than $30.
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
