305 TPI heads on 350 engine ???
Old Nov 1, 2008 | 01:56 AM
malibulvr's Avatar
Had these in the shop for a while. Took them from an '89 IROC Z 305 TPI engine. They look to have small chambers. Am building a 350 carbureted engine with dish top pistons. Was wondering if anybody had tried using a set of these with good or bad results.
Old Nov 1, 2008 | 10:06 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 TPI heads on 350 engine ???
I've done the 305 heads on a dished-piston 350 thing before, and while it's not ideal, there's nothing to cause problems except for compression ratio. I was using a stock '78 shortblock, and '83 L69 heads. I figured about 9.8:1, and it was in Reno, NV, in the summertime, I had detonation with just 26 total degrees of advance at cruise when I heard it. I'd driven it like that to South Carolina and back without hearing any.
Using an RV cam like the Edelbrock Performer 2102 might have helped. I was using the '78 cam and worn (stretched) timing chain. Also, I was running 1800 rpm at 65 mph, but I think I was running more like 55. I shifted down to third, and the next day, the car was totalled. Oh well.
You can get dished 350 pistons with a dish of as small as 10cc to as large as 30cc.
Old Nov 1, 2008 | 11:03 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
there ok if you cant buy some afr's or darts, but i would go flat top. you should be able to drive it fine on 91
Old Nov 1, 2008 | 01:57 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
and that's based on what? have you tried it like I have? I'm also a professional automotive machinist. I try this stuff so I can be more knowledgeable for my customers. Flattops with Vortecs usually works, but they're 62cc, while LB9 heads are 55 cc. 11:1 with LB9 heads only works on E85 or race gas.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
