Having same problem. Car produces white smoke
Old Nov 1, 2008 | 04:25 PM
Raz's Avatar
Raz
I just finally got around to replacing my intake manifold gasket in the upper phenom and got it all put back togather. Bought a $90.00 12v battery and started it up. It's been sitting for 2 months and at first choked out. But then turned the key again and ran fine. Turned the car off and on agian and white smoke keeps comming from the back of the engine; closet to the firewall. The car seems like it's idoling but not too rough and when i let it sit the rpm drops below idol (1000 rpm). I did however put in "high perform oil" while other oil was in it so it got mixed. Could that be a cause? The smoke doesn't smell like gas but has a oder. Agian it's cloudy white smoke but not visibal where exactly it's comming from.
Old Nov 1, 2008 | 04:30 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: Having same problem. Car produces white smoke
could be a head gasket check your engine coolant and see if its low if it is fill it up and watch it to see if it goes down if it doees it prob a head gakset
Old Nov 1, 2008 | 05:16 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
White smoke is almost always caused by burning coolant. The smell is usually a "sickly sweet" smell, makes me nauseous if I smell it too long. My guess is you sloshed coolant onto the exhaust system when you took the intake manifold off. Now that you are starting the car up, its burning off the hot pipes. Check your coolant level and keep a close eye on it. If it's not going down any, you should be fine. Once the car cools down, feel around the back of the engine as best you can and check for wet spots. Better yet, crawl under the car with a flashlight and look around at the back of the block/heads and see if anything is leaking.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
squiggy2
Aug 9, 2015 09:30 PM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
