ICM going bad
Old Nov 3, 2008 | 04:54 PM
jbates346's Avatar
ICM going bad
What are some signs of an ICM starting to go bad? Sometimes my '88 305 TPI doesn't want to start. I know its not getting fuel and from what i understand the ICM controls the injectors during start-up. This true? Would this be a problem right before the ICM totally fails? Any ideas or suggestions would be appreciated.
Old Nov 3, 2008 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
ICM = "Ignition Control Module". It's in the distributor, and does not directly control the injectors.
The ECM, "Engine Control Module", controls the injectors.
How do you know it isn't getting fuel?
Old Nov 3, 2008 | 06:18 PM
jbates346's Avatar
Re: ICM going bad
Well one of the times it wouldn't start i sprayed carb cleaner past the throttle plates and it fired right up. So its obviously not getting fuel. My question is why tho? And why is it only sometimes?
Old Nov 4, 2008 | 02:33 PM
five7kid's Avatar
Have you checked the computer for trouble codes?
Old Nov 4, 2008 | 06:30 PM
jbates346's Avatar
Re: ICM going bad
No codes and no codes in memory. I'm starting to think my ECM is wigging out. Please see my thread in the electronics section. I would appreciate your input there.
MM2Robinson
Oct 1, 2017 09:16 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
