89 gta brake problem need help.
Old Nov 3, 2008 | 10:15 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
To make a long story short I am trying to change the rotors and pads on the back wheels. I started on the passanger side. put the pads and rotor on it was hard to fit on the caliper to rotor but i got it on. now i went to do the driver side and i do not have the room to put the pads on and get it on the rotor about a half inch to much i tryed compressing the piston back into its bore with my c clap but the piston will not move much.. what should i do. my dailydriver is down.
Old Nov 3, 2008 | 11:06 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: 89 gta brake problem need help.
if you have the iron Delco calipers, the pistons are designed to be screwed back into the bores. if you have the aluminum PBR calipers, the pistons should be able to be pushed back in the bores, if not the pistons might be seized and in need of rebuild or replacement
Old Nov 4, 2008 | 12:12 AM
Car: 91 formula
someone just told me to open the bleeder screw and try and depress it. is this right.
Old Nov 4, 2008 | 04:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
That'll make it easier but you should be able to compress them with the bleeder closed.
Old Nov 4, 2008 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An 89 should have PBR's. Make sure the new rotors are seated against the axle flange--the last set I had forced me to pound on them a bit with a rubber mallet.
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
