i need help!! stock rs 350 vs gto,350z,cobaltss
Old Nov 7, 2008 | 09:15 AM
80sbaby's Avatar
Im a yung guy and i have some friends who are into cars as much as i am, however some of them are very fortunate 4 of them have pretty much new cars with that new speed i have 92 25th anniversary camaro with a stock 350 my friends in our little crew have a 06 pontiac gt0 (ls2) ,an 07 nissan 350z, 01 dodge srt4 and a 06 chevy cobalt ss turbo and supercharged
" what do i need to do to my stock 350 to blow the paint off of there cars cuz i hear it everyday about i need a new car camaros are shyt"
camaros are my favorite cars especially 3rd gens and i definitley gotta shut them up soon
Old Nov 7, 2008 | 09:31 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: i need help!! stock rs 350 vs gto,350z,cobaltss
You need to spend some time reading about the mods you can do, make some decisions about your budget and the ways to acheive your goals, and then revisit this topic. The cars you listed run from mid 14's right on down to low 13's, you need a 12.90 or faster car to beat the GTO consistently. Doing that on a TBI 350 would require some significant breathing mods (heads/cam/etc) or a lot of juice and some chassis mod's to plant the power.
Old Nov 7, 2008 | 09:45 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I agree, your going to need a new exhaust including headers, cam, intake, heads, and you may touch 13.00 with 3.73 gears you might be able to beat the GTO. When I raced them, they always raced around the 12.95-13.10's
Old Nov 7, 2008 | 11:40 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Do you know anything about the istory of the 350 in the car now like what it came out of or the heads or cam it has. that would go along way towards pointing you wer to start. if it a lo5 out of a caprice it's going to need head before it will ever be able to be competitive with those other cars. it depends on what you want under the hood if efi is your thing then a swap to a SD tpi ecm with a hsr or miniram and a good set of heads with a decent cam not one of those lt1/lt4 cams not bad cams but not what you will need.
is the car an auto or manaul tranny. if its an atou you'll need a higher stall converter if its a manual you may want to look into a t56 swap bc the t5 is considered weak for performance use.
Old Nov 7, 2008 | 01:02 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Is the engine in your RS original? The RS came with 305 not 350's that's why I am asking.
Old Nov 8, 2008 | 11:46 AM
80sbaby's Avatar
WOW!!! THANKS GUYS YEA WELL THE CAR WAS MY UNCLES FATHERS and then his dad gave it to he and he was goin to give it so his son but he didnt want it so i took it off of him but yes you are are right it did come with a 305 originally but he swapped it out for a 350 not sure where it came from but i can ask
Old Nov 8, 2008 | 12:03 PM
80sbaby's Avatar
and yea i kinda figured those mods would be needed i just didnt know if id have to basically put alot of money in the motor when i could just buy a gto or 350z which i dont want to do but is there any specific setup u guys would recommend??
Old Nov 8, 2008 | 12:38 PM
atc3434's Avatar
Car: 1986 Camaro SC
Search is your friend.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
