Loud thud when i give my 91 T/A some gas
Old Nov 7, 2008 | 04:55 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Every time im pulling out of my street i hear a loud thud come from either the tranny or rear. my dad says i might need a new yoke. any other ideas?
Old Nov 7, 2008 | 05:00 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: Loud thud when i give my 91 T/A some gas
Transmission mount is likely broken.
Old Nov 7, 2008 | 05:07 PM
Gary Berg's Avatar
Axle/Gears: Posi.
wat should i look for? a crack in the mount?
Old Nov 7, 2008 | 05:10 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
Take a lever, like a crowbar under the car with you and lever up the back of the transmission. You'll know pretty quckly if it's broken...
Bottle jack works too. Or a scissor jack etc...
Old Nov 7, 2008 | 05:17 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
it could be rear control arm bushings too...
Old Nov 7, 2008 | 05:24 PM
Stephen's Avatar
Car: 87 GTA
I agree with the broken tranny mount too. If you have a T5, it is more easily noticed, by the shifter movement, than it is on a 700R4.
Old Nov 7, 2008 | 05:51 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
tranny mount most likely they go all the time use an energy suspension one or similar
Old Nov 7, 2008 | 06:52 PM
Gary Berg's Avatar
Axle/Gears: Posi.
how much would that run me?
Old Nov 8, 2008 | 10:48 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You should be able to get one at your local AutoZone for cheaper than paying the handling fee from Summit or Jegs. I haven't bought one in a while, but it's likely around $15.
Old Nov 8, 2008 | 10:55 AM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Yup, its most likely your tranny mount. I had to replace mine once already, and I may have cracked this one too. You can get one from Advance or Napa, they run around $10 if I remember correctly.
Really easy to replace too, wont take you much time at all.
Old Nov 8, 2008 | 10:52 PM
Gary Berg's Avatar
Axle/Gears: Posi.
ok good it sounded expensive at first. thanks alot!
chazman
Aug 28, 2018 03:25 PM
maroe624
Apr 16, 2017 08:29 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
