Length of oil dip stick?
Old Nov 9, 2008 | 07:31 PM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
I have a 88 IROC with a TPI 305 engine. The service manual says that the engine needs to have 5 qts of oil when you change it, with a filter change. When I changed my oil and filter the dip stick reads full at only 4 qts. And yes I have run the engine and waited a few minutes to check again. Now Im wondering if I have the correct dip stick and maybe its to long. So if you have this engine would you please go measure your dip stick for me? Measure from the top of the t handle to the tip of the stick.
Mike
Old Nov 10, 2008 | 02:43 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Length of oil dip stick?
Did you put any oil in the filter? I always do. Depending on who you ask it is not always necessary but I like to. This may account for the reading you are getting on the stick.
Old Nov 10, 2008 | 05:56 PM
GT150's Avatar
Car: 1988 IROC-Z
I did fill the filter prior to putting it on. After running the engine and letting it sit for awhile, the dip stick read "full". But I still have one quart of oil left in a 5 quart jug...............weird.
My dip stick measures 27 and 3/4 inches long.
mike
wigmobile
Feb 26, 2025 02:56 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Ragtop Man
Sep 12, 2015 12:23 AM
