I need some help with a issue i got!!! PLEASE READ AND RESPOND!
Old Nov 12, 2008 | 12:19 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Also I have a running issue that I need help shooting down. My car idles fine but when I push down on the gas the car acts like it wants to die. Also once i get it warmed up the car doesnt want to start anymore after its at operating temperature. I also have to keep feathering the pedal to get the vehicle to move anywhere(mash on the pedal up and down)
I've recently changed my spark plugs and fuel filter. Cap/rotor and wires were changed back in jan., ignition control module checked out when I had it tested and the coil is also still good.It has a bad maf sensor but I have a MAF sensor on the way yet the maf has been bad for a while and the vehicle ran fine without it hooked up for the longest. I also ordered a BBK afpr from summit. I also just installed a new coolant temp sensor. Could it possibly be that my TPS sensor went bad? Any ideas or thoughts would be great! Thanks
Oh yeah I also have egr blocked off with caps on my edelbrock headers air tubes and the rest of the emissions removed but the car was running good for a year without any emissions so i doubt that that's where my problem lies.
Again, please give me your thoughts and help me trace this problem down.
SPC Davis
Old Nov 17, 2008 | 08:58 PM
Car: '87 Iroc-Z
Re: I need some help with a issue i got!!! PLEASE READ AND RESPOND!
TTT
Okay, I just put on a BBK afpr but that did not help. The car starts and idles fine but its having the same problems, also after the car is warm it will not start back up!! ANYBODY! HELP!!
Old Nov 18, 2008 | 02:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That first problem is caused by suddenly going lean. I would start with the TPS, but it could be something else.
Old Nov 18, 2008 | 03:12 PM
Car: '87 Iroc-Z
So by a new TPS sensor and come by and tell you what happens.
Old Nov 18, 2008 | 04:09 PM
Car: '87 Iroc-Z
I just changed the fuel pressure regulator with a BBK afpr and before I changed it fuel pressure was 20 psi on the gauge and after I changed it out fuel pressure was still 20psi but bounced around on the gauge.
I think my fuel pump is bad cause i cant here it click on or make any whining noise or anything.
Old Nov 18, 2008 | 04:15 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
bummer :/ you gonna drop the rear or make a access door ?
Old Nov 18, 2008 | 04:24 PM
Car: '87 Iroc-Z
pay a shop to put in my BBK in-tank fuel pump. How much do you think this might cost at a speed shop? what about a dealer?
Old Nov 18, 2008 | 09:20 PM
jackel200269's Avatar
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
I would bet anything that your pump its self is fine. Id say that the 3" piece of gas line that connects the pump to the sending unit blew. I spent a grand and tons of hours trying to fix that exact same problem. So I cut a hole in the trunk, pulled the sending unit and wala there it was a 3/4" blow out in the gas line. The mear fact that the pump is running is a pretty good indication that the pump is fine. It is very rare for a pump to loose pressure.
Old Nov 18, 2008 | 09:37 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Did you check or replace the TPS? Never cut a hole in your floor!!! (Unless you would use duct tape to hold a loose fender on.) It only takes a few hours to remove and replace your fuel pump. Do it the right way.
Old Nov 18, 2008 | 09:53 PM
Car: 92 camaro
Engine: lo3 v8
Wow was that a cheap shot at me. Mine is very trick. I cut my hole then I ussed a bigger piece of aluminum sheeting to fill the gap. I siliconed it down then I drilled in some rivets around the perimiter. Doesnt leak, only takes about 15 minutes to change my pump, and you cant see it when you lay the carpet back down.
Old Nov 19, 2008 | 07:16 PM
Car: '87 Iroc-Z
dont hack my thread
and no a my local speed shop will do it for $150 labor. I cant here the pump come on so how do i know its on?
No i havent changed the TPS sensor yet. But what does that have to do with my pressure only being at 20psi?
Old Nov 20, 2008 | 03:08 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
150 is a deal to get a pump replaced.
Old Nov 20, 2008 | 03:27 PM
Car: 92 camaro
Engine: lo3 v8
Sorry I wasn't trying to hack your thread, just thought I would try and help.
Old Nov 21, 2008 | 11:57 AM
Car: '87 Iroc-Z
yeah $150 labor, Im going to get a Walbro loud whine pump and see what happens
Old Nov 21, 2008 | 01:02 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Check your injectors, I had a similar problem, somone else posted a thread recently in here with similar simptoms too. When the mechanic found the injectors were bad he tested it with a node light, I would recommend having someone look at it who is fammiliar with it. When they looked at mine, the light was still getting a signal and blinking, but it was dim. i would have assumed the light at all meant it was good, but the mechanic said there was a short in two of the injectors which was causing a draw on the whole system. he picked all this up by haveing the node light and noticing it was flashing dimmer than usual It took an entire summer to get it resolved a few shops, and many mechanics.
Old Nov 21, 2008 | 01:19 PM
Car: '87 Iroc-Z
okay, well im just going to replace the fuel pump and the injectors, i dont want to test anything.
Old Nov 21, 2008 | 04:22 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
hey, you will have two new parts you wont have to worry about for a while if you look on the up side
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
