Speedometer cable?
Old Nov 12, 2008 | 02:29 PM
WhtIroc's Avatar
Speedometer cable?
So I have this problem, whenever it's cold outside, and I get in my car and get ready to drive it, once I hit around 15mph, I hear a whining noise coming from my car, and my speedometer goes up even when I'm not going faster. This ONLY happens when it's cold. I have no idea what it is, or how to fix it, and if you know it'd be awesome.
Old Nov 12, 2008 | 03:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer cable?
Welcome to TGO. Adding your car details, such as year, make, model, is helpful. If your car is an 85-89 IROC, the speedo will be cable driven. If that's the case, the cable probably requires cleaning and lubing.
https://www.thirdgen.org/forums/inte...ghlight=speedo
JamesC
Old Nov 26, 2008 | 07:54 PM
WhtIroc's Avatar
Yes, it's a 1987 IROC-Z, Carbed and Automatic. Bone stock, no mods.
If anyone can tell me if driving with the cable disconnected cand damage anything, that would be great too!!
Old Nov 26, 2008 | 08:30 PM
JamesC's Avatar
If you unhook it at the trans, there'll be a fluid leak. The best bet is at the cluster.
JamesC
Old Nov 27, 2008 | 02:51 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Also the vehicle speed sensor is on the back of the cluster so the computer won't be able to properly control the fuel mixture, thottle kicker, or the transmission converter lockup with the speedometer unhooked.
It sounds to me like a dry speedometer cable or head unit.
Old Nov 27, 2008 | 07:23 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i had that problem just put some grease on the end of the cable where it goes into your cluster did the job for me
Old Nov 27, 2008 | 02:13 PM
WhtIroc's Avatar
Thanks for the responses, really helpful.
My family has three vehicles, which two don't work, and one won't pass inspection.
I really need my car too! Lol.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
