Leakdown Test Results (On Stand)
Old Nov 13, 2008 | 10:22 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
This was done cold on the stand, forged pistons, and large (.024" top and .019" 2nd) ring gaps.
The cylinders weren't honed again since the last rebuild had less than 20 miles on it and I re-used the rings.
All done with 100 PSI in. Results will read PSI out.
#1 = 86 psi
#2 = 89 psi
#3 = 95 psi (Heard bubbling with this one...)
#4 = 91 psi
#5 = 92 psi
#6 = 96 psi
#7 = 89 psi
#8 = 88 psi
All the values could potentially be +/- 1 due to the gauge.
Old Nov 15, 2008 | 02:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Leakdown Test Results (On Stand)
Anyone care to comment? I don't know what to exactly make of these numbers (or what can be made since its on the stand and cold).
Old Nov 15, 2008 | 06:21 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Looks pretty darn good for a cold motor with those ring gaps. Let it run in for a bit and check it warm they should be sealed up tight.
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
PurelyPMD
May 5, 2016 04:57 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
ericjon262
Sep 11, 2015 06:07 PM
