need help identifying head bolts
Old Nov 15, 2008 | 09:11 AM
Camarogeddon's Avatar
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
I'm trying to figure out whether i should replace my headbolts or not, I'm fairly sure i already have an aftermarket set, but i want to make sure.
Does anyone recognize the symbol on the top of this bolt?
-Camarogeddon
Old Nov 16, 2008 | 04:43 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Re: need help identifying head bolts
Can't say I recognize that. Just get a new set, maybe $20 or so per side. IIRC, I got a GMPP head bolt kit for about $40 for both heads.
Old Nov 17, 2008 | 10:41 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ARP head bolts cost about $90 last I checked. Shipping to norway probably takes 4-5 weeks, and is astronomical in cost.
if you already have the parts....
I'm sorry Carmeggedon, I don't recognize that symbol. I am curious however, so i'm hoping somebody chimes in.
Old Nov 17, 2008 | 07:28 PM
spills's Avatar
Car: 89 RS
ARP is gonna run ya bit higher than regular aftermarket head bolts though. If it's a regular 350 with nuthin special, standard headbolts should suffice. If you're boosting or jucing, definitely ARP
evilstuie
Jan 9, 2020 08:29 PM
Redwhisper
Aug 26, 2015 05:02 PM
355tpipickup
Aug 25, 2015 12:54 AM
Linson
Aug 21, 2015 02:12 PM
