Driver side cyls dead....
Old Nov 15, 2008 | 08:28 PM
jsantoro's Avatar
Hi All, I have an 88 5.7 L TPI in a street rod. The drivers side cylinder are not firing at all. All injectors 16-17 ohm. They have juice and look like they are ok with a noid light on them. Spark to all cyls. Swapped ecm with a spare. Was fine then this happed yesteday when starting form cold. Could half the fuel rail be clogged? What am I missing here?
Regards,
Jim
Old Nov 15, 2008 | 10:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Driver side cyls dead....
Do they have +12v on them? It's the ground that's switched by the ECM.
They are usually two fuses, one for each bank, that provides the +12. There are also two drivers in the ECM that provide the ground.
Old Nov 16, 2008 | 12:27 PM
jsantoro's Avatar
Yes, all have 12v on them. I swapped out ecm's just in case. Noid light blink on all injectors.
Old Nov 16, 2008 | 03:43 PM
jv9999's Avatar
Engine: 5.7L/350
-Hmmm, do you have fuel pressure? How do you know they are not firing?
Old Nov 16, 2008 | 04:07 PM
jsantoro's Avatar
Yes, fuel pressure is 40 lbs. It's running on the pass side 4 cyl. not drivable of course. ican pull the drivers side plug wires and it makes no difference. or i can pull the injector connectors and no diff. I know i have spark. new plugs, wire cap rotor. timing @ 6 deg w/est disconnected. and the niod light say the injectors are firing. guess i have to pull the fuel rail and actuall see.
Thanks.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
