can i re use these rings
ok so i bought a rebuild kit with piston rings from summit and the oil spacer rings were manufactured wrong so they arent useable (i was told this by my uncle who is a mechanic)... can i use the old oil ring spacers or use oil ring spacers from another 350?... just an idea that popped into my head
Re: can i re use these rings
they are too hard and the oil rings cant compress it so its putting too much pressure on the cylinder walls.... my uncle said that they cant be used or fixed so they are garbage now... the manufacturer messed em up
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Much more likely you've either got the wrong rings for the bore size, or they were installed wrong.
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Get ahold of Summit Customer Service, or the company that makes your rebuild kit. That's what warranties and guarantees are for man.
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
you bought a defective product, they need to make it right. Trending Topics
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Were you the guy who posted about this same problem about a week ago, and got the same response?
Your uncle is probably mistaken. Rings are RARELY "made wrong", whatever that even means... If it makes you feel better, return them and try again. My guess is that perhaps somebody on the production floor mismatched the wrong bore size oil control rings in that box - or you're just being a hypochondriac
Are you using the old pistons? If so, did you clean the ring grooves? You need to get the crap out of the groove or you will have the same problem you are describing.
LT1Formula
Oct 8, 2015 08:34 PM
