does anybody know how to switch out a tbi manual trans and put a tpi setup
Old Nov 19, 2008 | 07:17 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
I've got an 88 camaro with a tbi setup manual transmission and I want to put this tpi setup that I got off an automatic, need help stting up the wiring harness and need to know if the ECM is I got with it is ok to use on a manual trans?
Old Nov 20, 2008 | 11:48 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: does anybody know how to switch out a tbi manual trans and put a tpi setup
there should be no issues, except it would be easier if you got the TPI ECM and wiring harness
Actually i think you NEED the tpi ecm, the trans part shouldnt matter if i remember correctly, but dont quote me on it
do a search, alot of TBI to TPI swaps have just spliced the harness in various places to get it to work
Old Nov 20, 2008 | 01:30 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
well I do have a tpi ECM and wiring harness, but it's off an automatic will it. Matter
Old Nov 20, 2008 | 11:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
shouldnt, the only hook up that would be different would be for the trans but if you have the engine harness it wont matter as far as i know
Old Nov 21, 2008 | 08:30 PM
peanutmrpeanut's Avatar
the ecm for an auto worked fine in my car. It was a tpi 350 only thing I noticed that didnt work that worked on a 5sp car was the shift light that was on the dash other than that it all worked great.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Sep 3, 2015 10:56 PM
squiggy2
Aug 9, 2015 09:30 PM
Leggman1
Aug 6, 2015 04:15 AM
