WTF is this???
Old Nov 21, 2008 | 06:58 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
WTF is this???
I was under the car changing out the positive battery cable and saw this:
Attachment 167369
Help me out here. Where does it go? That is the back of the starter you are looking at just in case anyone was wondering.
Old Nov 21, 2008 | 07:35 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: WTF is this???
that looks like the connector for either the knock sensor(located on the side of the block in front of the starter) or cooling fan temp switch(if equipped with electric cooling fan)
Old Nov 21, 2008 | 07:37 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Re: WTF is this???
Ditto....looks like one of those two.
Old Nov 21, 2008 | 08:17 PM
chesterfield's Avatar
Car: Pontiac
Re: WTF is this???
Is that a knock sensor behind the tip of the thumb?
Old Nov 21, 2008 | 08:19 PM
Twin_Turbo's Avatar
Re: WTF is this???
It's indeed for the knock sensor, you can see the sensor is not hooked up, just next to your thumb.
Old Nov 21, 2008 | 08:31 PM
DirtyCanadian's Avatar
Re: WTF is this???
Thats new to me What does the knock sensor do? and what years of trans ams are equipped with them?
Old Nov 21, 2008 | 08:35 PM
Twin_Turbo's Avatar
Re: WTF is this???
All GM EFI systems have a knock sensor (even the computer controlled q jets have them), basically if your car has a EST controlled HEI, it has a knock sensor.
Anyway, it's sort of a microphone and is used by the ESC (electronic spark control) to "listen" for characteristic accoustic signals indicating detonation (the knock sensor is engine specific, they are not all created equal). The knock sensor is hooked up to the ESC, basically an interpreter/amplifier. This signals the ECM in case of knock and then the ECM tells the ESC to back off the timing until the knock is gone, the EST then starts advancing the timing again.
Old Nov 21, 2008 | 08:52 PM
Re: WTF is this???
Ok that would be why i dont know about it, I have only had plain Q-Jets.
Old Nov 21, 2008 | 09:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: WTF is this???
IIRC, 85 up had the sensor. Unsure about the Canadian cars.
JamesC
Old Nov 22, 2008 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, when they upped the LG4 compression to 9.5:1. L69's all had it.
Only L69's, and as I understand, the later LG4's (like '86-'87) finally had the CC carb. But, if not CC, no knock sensor (I believe).
Old Nov 23, 2008 | 01:52 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
Re: WTF is this???
if the knock sensor is broken or unhooked will you be able to hear knock or ping under hard acceleration?
Old Nov 29, 2008 | 11:32 AM
Re: WTF is this???
Old Nov 29, 2008 | 02:01 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: WTF is this???
It depends how bad it is. When I had my timing at 10, it would pull a little timing when I stabbed the throttle. Never heard a thing, but the knock sensor did.
Old Nov 29, 2008 | 02:54 PM
Regal105's Avatar
Engine: 454, 5.3
Re: WTF is this???
i think i need a new timing chain or something, my car knocks or pings i dunno whats what haha, my timing was 2 or 3 degrees retarded when i got it and i put it to 0 should i go higher maybe? i read somewhere tbi's like a little more timing?
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
