Installed 6al box with blaster coil.. now....
Old Nov 22, 2008 | 12:27 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
After not driving the car for about 3 weeks the battery was dead.. new battery and no problems before msd... I charged it ran for about 20 minutes and then it sat again for about a month and same thing. Also my tach breaks up after @3200rpm since the box was installed but seems to run okay. I have the 6al , coil and coil connector. Any ideas why it would drain the battery or break up the tach reading would be greatly appreciated. Thanks guys.
Old Nov 22, 2008 | 12:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Installed 6al box with blaster coil.. now....
You should disconnect the battery if you're going to park the car for an extended period of time.
Did you connect the tach to the tach terminal on the box?
Old Nov 22, 2008 | 01:07 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
No the harness for the coil is supposed to eleviate the need to run the tach wire.... just a plug and play deal. As far as the battery I never had a problem letting it sit for a few weeks until the 6al box, could it be a bad ground?
Old Nov 22, 2008 | 01:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it's just the nature of the beast. The box is connected to unswitched battery power. Leaving the car for weeks will drain the battery.
Old Nov 22, 2008 | 01:29 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Thanks Apeiron, Ill make sure to disconnect the battery from now on. Ps I just took the car for a drive and I tripped a ses light code 24(vehicle speed sensor) but I dont have a vehicle speed sensor its an 87 with a mechanical speedo. What gives? Any thoughts?
Old Nov 22, 2008 | 01:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
An 87 Firebird should have an electronic speedo. Even cars with mechanical speedos have a VSS though, it's on the cluster on the back of the tach.
Old Nov 22, 2008 | 01:43 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Just checked. I shouldnt admit this but...... I resealed my governer cover cause of a leak and I never pluged the speedo back in.. ...another proud moment,lol.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BigJon88
Aug 19, 2015 10:09 AM
bryan623
Aug 10, 2015 11:33 AM
djmarch
Aug 9, 2015 05:27 PM
