Jacking The Front End Of A 305
Old Dec 2, 2008 | 09:48 AM
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
I need to remove the ramps from under the front end of my Camaro. The intake manifold was removed therefore I cannot start the 305 to back down from them.
I have to make room for a newly acquired 2002 SS so I can roll my unfinished '88 IROC Z28 project out to the side for now.
Question is how do I safely remove the ramps by myself?
I thought about a solid block of wood under the oil pan and just below that piece of wood is my low profile 4 ton jack to lift the entire front end quickly to remove the ramps.
Any other lifting points would be appreciated.
Thanks In Advance!
Old Dec 2, 2008 | 09:56 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Jacking The Front End Of A 305
Not wise. Better, put the jack under the frame crossmember that goes under the front half of the engine.
Old Dec 2, 2008 | 10:03 AM
kcb37's Avatar
I would set it under the k member.
You could lift it just enough to get the tires off the top of the ramps, pull the ramps forward, set it down, get in it, and let it roll off.
Or you could lift the contorl arm one at a time and move the ramps forward to do so.
I would recommend not having anything real close behind if you do this.
Might be easiest to raise each contorl arm as you won't have to lift it real high. Your going to have to go pretty high to get the tires off the ramps when the tires droop with the supsension.
Old Dec 2, 2008 | 10:04 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Just give it a push.
Old Dec 2, 2008 | 09:22 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Old Dec 2, 2008 | 09:28 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
I put my car up on ramps all the time, but I have never driven it up the ramps. I don't want to mess with the starter blocks, etc. I use the nice subframe spot on each side.
So, I just jack up one side real high and slide the ramp under the tire. Let it down on the ramp then move to the other side. Repeat.
Just reverse the procedure to get back off the ramps.
Old Dec 2, 2008 | 11:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Use the K-member and a good floor jack with a decent ammount of travel. The k-member is strong and is the recommended spot to jack. Doing one side at a time could make the car unstable and cause it to fall off the remaining ramp. It can also damage the subframe rails.
Old Dec 3, 2008 | 12:19 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
I have also hear horror stories about cracked windshields when jacking a car up too hight on one corner. I would use the K member personally.
Old Dec 3, 2008 | 04:47 PM
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
Thanks for all the helpful advice. I jacked my Camaro by using the crossmember near the 305.
After careful removal I was satisfied with the proper lifting point.
Click to view.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bellez77
Sep 5, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
