timing cover moving in and out when engine is running
Old Dec 4, 2008 | 05:00 PM
dexint's Avatar
just got my car running and i noticed right away that the timing cover is moving in and out like somthing is rubbing on it inside the cover, any ideas what would make this do that ,its a 1992 camaro rs 305 v8 and i can see some oil leaking out from under the balancer not alot though i think its from the timing cover
Old Dec 4, 2008 | 05:19 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: timing cover moving in and out when engine is running
Sounds like you need to tighten your cam retaining plate. It's 2 torx bit bolts behind the timing cover.
Old Dec 4, 2008 | 09:35 PM
dexint's Avatar
if my timing chain or set is going bad does anyone know since it has a crane compu cam aftermarket cam if it still uses the stock timing set or diff
Old Dec 5, 2008 | 03:54 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Should still use stock.
Frozer!!!
Jan 19, 2024 04:55 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
