help...damper issue
Old Dec 11, 2008 | 12:04 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
help...damper issue
92 350 tbi- original balancer spin so i bought a new one. installed it and now timing mark does not line up to 0* on the indicator when motor is at TDC. whats going on?
Old Dec 11, 2008 | 01:05 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: help...damper issue
Probably got one for an earlier engine. The timing tab (Saw blade) is further to the drivers side on earlier engines. I believe that you can get a decorative cover for a newer engine.
I think this one might work:
http://store.summitracing.com/partde...C&autoview=sku
Or you could get a degree wheel and re-mark the one you have. Or return it and get the correct one.
Also, did you use the correct tool to install it. If you use a hammer to install it you can damage it.
Old Dec 11, 2008 | 06:10 PM
Colts45s's Avatar
Car: 92 camaro rs
i used the correct tool, no hammers here. are you saying that on a 92 the timing indicator is not at the 2 oclock position?
Old Dec 12, 2008 | 06:49 AM
Damon's Avatar
No, not on a TBI engine. It's at 12:00 right behind the water pump. I still have the factory original dampener off a 92 RS 305 TBI motor and it's a 12:00 position dampener.
TPI engines used the more typical 1:30 position dampener I believe, however. Same years, different engines, different position dampeners.
Old Dec 12, 2008 | 07:31 PM
Colts45s's Avatar
Car: 92 camaro rs
ok cause i think my motor came out of a 93 1500 chevy pickup 350 and the timing cover is set up for 1:30 indicator. Can I just get a balancer for the 1:30 position cover?
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
