Changed starter, now no power?
Car: 1988 Trans Am GTA
Engine: 5.7 L98 Supercharged
1990 camaro Iroc-z 5.7 liter
Just changed starter today, and had the battery unplugged the whole time (about 3 hours because it was my first time...)
I put the battery back in after a charge, which the multimeter read 12.7 volts, and the car had absolutely no power. no inside lights, no headlights, the ign wouldn't make any sound or lights when turning.
Anybody got an idea?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Changed starter, now no power?
Cables hooked up to the starter and engine correctly? Clean connections?
I did see another wire down there that wasn't connected to anything, I think it was black and had a open wire coming out the end that looked like a very small clothespin... if that helps.
There is a connection from the ground terminal at battery to the alternator bracket, so I don't think grounding is a problem.
Though, there is no continuity between the alt. bracket and the dome light ground. Hmmmmmmmmmmmmmmmmmmmm
Transmission: 4L80E/4L80E
It goes to the same starter solenoid terminal as the battery cable.
mhatfield 14
Oct 24, 2015 07:48 AM
92camaroJoe
Aug 13, 2015 06:07 AM
