Fuel Pump Location?
Old Dec 16, 2008 | 05:21 PM
BthomasM's Avatar
Car: 1990 Firebird / 1999 Eclipse
Engine: 3.1 v6 / DOHC 2.0
Transmission: Automatic / 5 Speed Manual
Fuel Pump Location?
I have to replace my fuel pump and instead of dropping the axel and tank I'm going to cut through from the inside.
Anyone out there that's done this before?
Tell me about it
Old Dec 16, 2008 | 09:12 PM
PrdnJoy's Avatar
Car: 89 Firebird Formula
Re: Fuel Pump Location?
http://www.turbobuick.com/forums/tur...utes-less.html
Here is the link I used when I changed mine had it done in and hour...Hope this Helps..
Old Dec 17, 2008 | 12:22 AM
BthomasM's Avatar
Perfect!!
Old Dec 17, 2008 | 07:36 PM
PrdnJoy's Avatar
Your very welcome I see your also in Florida where abouts?
Old Dec 17, 2008 | 08:03 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
hey! let me first say welcome to TGO BthomasM!
And to you Prdnjoy,that ecm still holding up? (sorry but my car is still sporting the black/grey combo!) I kinda like it.
anyways,back to topic! I've never been a fan of the hack job fuel pump access hole but that link Prdnjoy posted looks pretty CLEAN!
Old Dec 17, 2008 | 08:28 PM
Stephen's Avatar
Car: 87 GTA
This topic is covered WEEKLY.
To pull the pump out, you'll hafta find a way to cut the hard fuel lines & then reconnect them, without them leaking. For carb &TBI engines, that is easy...low pressure TPI uses a higher pressure,which is harder to seal.
Old Dec 19, 2008 | 02:02 AM
BthomasM's Avatar
I live in Ocala.
It will probably be a couple weeks before I make the access panel, I'll try to post some pics of it when I'm done.
Old Dec 19, 2008 | 09:19 PM
PrdnJoy's Avatar
And to you Prdnjoy,that ecm still holding up? Tim all is Great can't Thank You enough..(sorry but my car is still sporting the black/grey combo!) I kinda like it.(Did I ever tell you it would be SHARP black on black)
As for Hack Job it come out beautiful I used a tubbing cutter didnt crimp lines at all..Buy the way Tim that is on a new car I purchased a 1991 Firebird v-6 had to replace fuel pump (I havent posted that car to this site)
BThomas pics would be nice.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
