v-belts to serpintine will it work??
Old Dec 20, 2008 | 10:14 PM
jfsiutza's Avatar
Car: 1986 Z-28 al unser silver bullet
Engine: 305 carbed
Axle/Gears: 3.08
ive got an 86 with v-belts and i was just wonderint if its possible to swap to the 89 serpentine belt. ive heard the pumps are different and it would cause it to over heat is it true???
Old Dec 21, 2008 | 12:06 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: v-belts to serpintine will it work??
As long as you get the correct water pump, it will be fine.
Old Dec 21, 2008 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I swapped from V to serp. The following link(s) might give you some ideas:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Dec 21, 2008 | 02:10 PM
jfsiutza's Avatar
Engine: 305 carbed
Axle/Gears: 3.08
thanks
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
