will i be able to have an A/C ??!!
im looking at an 86 iroc that i may buy, its cheap, the body is straight, it already has a 3.73 posi with disk brakes. But it looks like someone has taken out the a.c compressor and lines. From the pics i have seen the a/c condenser is still there. Can i still put an a.c back in it? or is it done for?
also i plan on an ls1 swap at some point.
Car: 87 GTA
Re: will i be able to have an A/C ??!!
Regardless of what has been removed, everything can be replaced.
I bet only the compressor was removed. Bolt a new one in, put a new condensor in & your good to go! Dash controls still there?
http://louisville.craigslist.org/cto/967945169.html
i really dont yet if i want it or not.. if i offer anything it will be $800
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
car looks decent for $800. just buy and ac compressor and get the system charged and it should work fine. on another note anyone know where that steering wheel came from. ive got the same one in my car and i dont think its a camaro wheel
mines got a bowtie in it
ive heard monte carlo, anyway sorry for the hijack
ive heard monte carlo, anyway sorry for the hijack Re: will i be able to have an A/C ??!!
i bought it ..
ill pick it up tomorrow... im pretty excited, its been 12 years since ive owned a camaro. I guess ill be on here alot now, look forward to getting know the site and other iroc owners.
Transmission: 4L80E/4L80E
When you put the AC back together again, you should replace the receiver/dryer. The condenser will probably be fine, but it should be checked out as part of the AC re-install (flushed, at least).
If you're putting an LS1 in it soon, you might want to just wait until then to put the AC back together, as the 3rd gen compressor and lines aren't a direct fit on an LS1.
2012sergen11
Oct 13, 2015 07:38 PM
